6.0 LS Swap/Build
#241
Curious if the NW throttle body is by wire or by cable? I'm not 100% sure on which way your going to set-up your car? I think that most drive by-wire setups use the front cam sensor pick-up and you have to install the drive by wire accelerator pedal. I went the drive by cable and re-used my stock accelerator pedal. The by-wire set-up is more complicated by will give you options down the road for the newer transmissions setups.
Good score on getting all those parts.
#242
Kind of goes both ways I guess. I got an entire intake loaded with fuel rails and injectors with TB for $550 for the LS. I don't think you could do that for a SBC intake that fits under the hood. On the flip side a ******* oil pan for the LS is $400 for an F Body pan
#244
I have a Camaro oil pan on my swap and I paid $125 for it used with sump tube included. I original had a Corvette pan with a Batwing, but when I put the Melrose Headers on I had to change, the pan. I also have a DBW setup that I was going to put on, but I brought a Edelbrock 90 MM TB, and don't want to spend the $$$ to buy another TB, I am saving up for a Procharger. I put a roll bar in the Vette over the winter. I was told by the tech official at Atco to slow the car down on the last day of test and tune last year.
Randy.
Randy.
#245
The 92mm Chinese ones are cheap!
#246
I run one of those cheap ebay 102mm cheap Chinese throttle bodies, that came with the TPS and IAC electronic parts. I remember it was less than $100. The IAC valve is pretty noisy, when the engine is cold (it whistles), I guess you could use a grind and smooth out the sharp edges.
I used the Holley low clearance oil pan, but I don't remember paying that much for it, of course that was 3-4 years ago. Our Canadian dollar was near par with the US back then.
#247
They are expensive-(I paid about $250 for mine) but the ls platform will be worth it in the end.
#249
These bitches found their way to my farm. Gonna try to copy what I saw on another build by cutting the collector off and welding on a 30* ish angle
#250
what are the details on the headers?
#251
They are C5 headers. somewhere earlier in this thread somebody posted some pictures of some headers that look like C5 headers cut off at the collector with a bend welded in. Instead of buying swap headers for $600+ I got these for $180. I reached out to the vendor on eBay and was surprised to find that these have a 3/8 thick mounting flange, constructed of 16ga metal, so I ordered them. They are actually half *** decent pieces. Fitment obviously doesn't matter to me because I'm going to cut them up anyway. I fully expect the paint to flake off within 5 minutes of the engine running lol
At that point I would likely wrap them to keep under hood temp down
#252
Cool! thanks for the info. You can always ceramic coat them after your done modifying them to fit for corrosion protection.
I'm looking forward to seeing how much (or little) work it will take to make the C5 headers work. Nice that they are 1 7/8 primaries, should be worth a little more HP compared to 1 3/4.
#253
#254
It seems like the C5 headers you have might be a great option if they fit without too much modification. I'm looking forward to seeing how they turn out. I really hope that it is just a matter of changing the angle of the collector, that would be really great news for anybody planning a C4 LS swap.
#255
Ya I've also been on the hunt for 1 7/8 LS swap headers since the 1 3/4 melarose headers are a little small for the 6.0L LS2 i'm planning to use in my 88'. I did find a place called BRP muscle rods that makes some for like $1000+ but they had very bad reviews, and that is a LOT of money to spend and find out that may not even don't fit properly.
It seems like the C5 headers you have might be a great option if they fit without too much modification. I'm looking forward to seeing how they turn out. I really hope that it is just a matter of changing the angle of the collector, that would be really great news for anybody planninh a C4 LS swap.
#256
Ya no way I'm paying $1000+ USD ($1350CAD) for the unproven BRP headers!
Another crazy header thought that had crossed my mind was to cut off the flange and say the last 6 or 8 inches off my existing SBC C4 headers and use a LS flange and some pieces of bent pipe to turn my existing C4 headers into LS swap Headers, I'm not sure how much work that would be though.....
Using the C5 headers will proabbly be less work I imagine. I look forward to seeing how it turns out
#257
Received 3,043 Likes
St. Jude Donor '05
Next time you see the old "ls swap it cheep" answers you can straighten them out
Keep at it, the 6.0 will move that car real good, great motors.
Ever consider buying flanges and making your own?
#258
Wow those C5 header look sweet, but the C5 collector takes a bend towards the bell housing and transitions backwards over the torque tube. I'm going out on a limb that your going to hack a decent piece (pie cut) and straighten out the collector. If you have access to a tig welder you could almost make them look factory.
I was wondering if the C10 LS swap headers or camaro LS swap headers would fit? There lots of room to fit headers on these cars once you get the AC evaporator out of the way. I started up my car earlier this week to find out one of spark plug wires wasn't connected fully to the spark plug. Was the first time this year I got to drive my car. Just about everyone stopped to take a look at the car and try to race me at what ever stop light I stopped at. Those 1 7/8 tubes makes my headers look pretty tiny.
I can't wait to see hoe everything looks going together for you. Thanks for sharing as much as you have.
#259
I kind of thought about it but figured it was easier to buy a set that was already built and just hack up the collector area. I've never welded a set of headers before
#260
Probably one of my best C4 mod so far to date.
