93 LT1 Service ASR with DTC 65
Good morning....93 coupe with an intermittent "Service ASR". The warning light pops on and clears when shut off. DTC 65 sets. I do have the FSM, but don't have the breakout box or adapter. FSM says to check for short in circuit. Question: can I use a digital multimeter to locate a short between pins on EBTCM connector to connector on Adjuster assembly?
Or is this a job for a professional? I'm planning on inspecting the cables visually, to see if anything look's corroded.
Thanks and a Happy Vets Day to all who served.
Proud Air Force Vet. 66-70
jph46 (11-22-2018)
