Super ram
Super ram
would it be worthwhile to go from my LTR AS&M runner and ported plenum setup and go to a super ram plenum? I already have the super ram base on. I’m running the lingenfelter 211/219 cam and AFR heads. In the middle of a tranny rebuild now but this would be the last big thing I would want to do to the motor.
No mention of your transmission, shift kit, and/or gearing. Maybe you are asking to determine what stall to install? Rarely do people talk of rebuilding ZF6...which is possible with your 89. Assuming you have an auto and the performance rear end for 1989, You'll definitely like the SR better ... especially for hwy passing and/or track racing. If you drive primarily around the city (like me), you may be happier if you stick with the long tubes. (In other words, if you drive in lower rpms way more often). That said, your heads are good enough and the cam is big enough (for those heads) that you'll definitely generate more horsepower with the SuperRam. FWIW, If I was running an automatic (unless it had hwy gears), I'd opt for the SR vs longtubes. No question.
I was looking at some old files last night and came across some dyno pulls of my car in 2003. The major components are ported 113 aluminum heads, LPE 219 cam, Superram, 1.6 rockers, and Hooker long tube headers. It never really had a good tune on it so don't take this as a perfect example, but here's an idea of the SR's power band if it helps you with decisions.
Received 1,405 Likes
It is worthwhile, but you really need the tune to set it up well. I run a SR.
Get the SuperRam. I ran one for decades. Great street/strip manifold. I only switched to a Miniram because my 84 is no longer a street car and I can eek out a few more high rpm horses with the Mini. The SuperRam has a huge, flat torque curve and mine pulled to 6400 (extrude honed though). You'll be more than happy with it.
From the old article: Ten Times the Torque, the Superram is worth about 20 hp over the the best LTR setup. See attachment. Its up to you if the 20 hp is worth the scratch for SR uppers. I also have a Superram. Turns out it also works very well with forced induction as the torque never really falls off with rising boost.
The following 2 users liked this post by tequilaboy:
Benny42 (09-01-2018),
ctmccloskey (09-19-2018)
Received 3,043 Likes
St. Jude Donor '05
KITT do the SR....port the daylights out of the base, thats a lot more restrictive than the runners. You can pull another 40cfm out of it if you got time..and are careful. Youll feel that
plus its Ca legal, not much is anymore. Do you own a TA with the KITT license plate, seen one running around.
Whaddya want for your ASMs?
Still 100+over stock not bad at all!
yeah I have an auto and 3.07 gears. I ordered a modified transgo shift kit from probuilt going to be part of my tranny rebuild. I’m going to order a vigilante torque converter. I actually already sent my info before thinking about the super ram. But have not ordered yet. I was thinking about a 2400 stall. That should be fine either way shouldn’t it?
I was never sure if I was going to ever switch since they are pricey. But since I just took some money out recently from the house decided to take care of some things. Including getting my car where I want it to be at. It’s going to be a bit though. I just ordered a bunch of transmission goodies. Ordering my torque converter tomorrow. I’ll be getting my tranny done first then install the super ram. Super ram is ordered from eBay. Looks original no polish or paint.
Originally Posted by GREGGPENN
I have an 89 with AFR 195's, 3.33s, and a 214/214 cammed 383 LTR setup. In my case, it's a pretty good match to stick with the tubes cause I like tons of street torque. It's right on the border of spinning in 3rd running 315's (depends on the weather/road conditions). I've considered swapping to an HSR (which runs out a hair more than a SR) but I might be less inclined to swap if I had 3.07s -- with my ZF6. With an auto though....yeah. Overall, with an auto, I still think you'll be happy with the swap to a SR.
To be honest, the biggest reason I've stuck with longtubes is how seldom I'm on the hwy.I hogged (megaported) SLP longtubes out so much, I was shooting for SR-like power curve and performance. For those of you who remember Mick Stevens, he cautioned me against actually using a superram. Mick said Lingenfelter [personally] told him manufacturing QC suffered at times -- meaning some units could have problems sealing (with lid). In the 10yrs since then, I can only remember one/two complaints on this board. IIRC, one of those was fixed with the manufacture of another lid. My setup was intended to avoid that possibility and appear a bit more stealth. Had I not been cautioned by Mick, I would have picked a SuperRam for sure. As it was, I still sought that same power curve...using an alternate method.
Here is my dyno from LPE. You can see most of the specs in my sig. Another vote here for the SR.
Which AFR heads do you have? Good luck with the Super ram!!
I put a Super ram on my 89 last winter, Been great so far! Followed installation tips from many on these forums, Vader 86 has lot of info on his site, Dmittz added a superram as part of his build, lots of info there (Thanks Guys). Had my 700R4 rebuilt and put in a 2500 stall TC. Added LT headers....next step for me is cam and new heads, How do you like the LPE 211/219? Looking at that vs. the LPE 219/219.
So how much of a pain in the butt is it putting the super ram plenum on? The AS &M runners were no picnic either for the bottom runner bolts. Have to have the valve covers on before putting those runners on. And use a small magnet to get the bottom bolts in. And they have to be Allen bolts so you can use a long ball tip Allen socket.
All in all took my time went pretty smooth, no vaccuum leaks when done.
I had the Superram with the 74219 cam. After tuning, it was great.
