Sort of C4 tech related, C4 drag car
Old 05-21-2018, 10:21 PM
tpi 421 vette
tpi 421 vette's Avatar
Hey Brian, that looks badass! Oh and I like your cylinder heads and valve covers
Old 05-23-2018, 11:13 PM
MatthewMiller
MatthewMiller's Avatar
Received 1,705 Likes on 1,291 Posts
I first noticed the cam specs and though, "that's a lot of cam." Then I looked up the specs for those heads. Yeah, that's not a lot of cam at all. In this day and age of big-inch SBCs and LSs, it's easy to forget how amazing the BBC can be. I'm guessing you're going to hit the higher end of your power estimate. Good luck! And we want videos with full sound!
Old 05-24-2018, 12:01 AM
cohoskip
cohoskip's Avatar
A an old dragster from way back when, I am in awe...
Old 05-24-2018, 01:33 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Nice, it takes a lot of time and money to create that and moreso make it work. Lots of dedication!
Good to see different builds once in awhile. 8s is hauling azz
Old 05-24-2018, 10:50 AM
bjankuski
bjankuski's Avatar
That is why I like BBC for drag cars and even hot street cars, it is amazing the amount of power you can get out of those engines. The heads flow very well and the power at streetable RPM ranges is amazing.
bjankuski
bjankuski's Avatar
Old 06-01-2018, 12:46 PM
NitrousSam
Support Corvetteforum!
NitrousSam's Avatar
Do you have any photos of it sitting on the ground? I am curious if you are running a 15x14 rear wheel or larger?
Old 06-01-2018, 11:14 PM
bjankuski
bjankuski's Avatar
33 x 16.5 x 15 tire
I can get some photo's tomorrow, i am racing and will take some pictures and report an ET and weight.
Added ET and weight in first post.
Old 06-03-2018, 10:41 PM
bjankuski
bjankuski's Avatar
Updated with info on the first post, related to ET and weight.
Old 06-04-2018, 07:56 AM
C409
C409's Avatar
..... Which EFI controller are you using ? .....
Old 06-04-2018, 08:23 AM
bjankuski
bjankuski's Avatar
Holley HP
Old 06-04-2018, 10:25 AM
383vett
383vett's Avatar
Received 1,544 Likes on 1,044 Posts
Really nice run!
Old 06-07-2018, 07:41 AM
  #33
bjankuski
bjankuski's Avatar
Quick Reply: Sort of C4 tech related, C4 drag car
