temp control door motor on my 90
Does anyone know where the temperature control door and motor is located on the 90?
How do i get to it?
Can I get to it from the engine side?
thanks,Laura
:seeya
How do i get to it?
thanks,Laura
:seeya
Re: temp control door motor on my 90 (LJAZZZ)
For the Model Year (MY)90, it's buried in the heating and ventilation assembly, passenger side. One of the most dreaded C4 jobs is replacing this motor. Believe book is around 14-16 hours and some shops will not accept the work. This motor installation design was changed in 94 and up and takes 5 minutes. Big improvement. You can install the 94 motor and housing on the 90 but need to move some wires on the control assembly. I have a box/motor off a 94 sitting in my garage. Paid $35. Just waiting for my 90's temp control motor heading south.
You are certain the motor needs replacing? The C68 electronic controls has some pretty good trouble shooting routines.
Hope you get everything fixed. Doable, but, darn dash work. I'd rather do my own dental work.
dlmeyers 90 coupe zf6 3 speed shocks
Re: temp control door motor on my 90 (dlmeyers)
Received 1,622 Likes
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Re: temp control door motor on my 90 (-=Jeff=-)
What did they change to make it easier?
Sonny Kilgo recommended moving the motor from the top of the box to the bottom because of warranty work they were having to do. They finally did this in '94. He got a $4000 bonus for this idea.
To remove the motor, there is a bolt on the top of it that sits just under the windshield wiper area. That means removing the entire heating/ac box assembly just to get to that one 7mm bolt.
Jerry Watts drew a diagram for me showing where to drill a hole just under the mesh by the windshield wiper so you can access that bolt from the top then plug the hole. Then you don't need to remove the entire dash assembly just to get the motor out. This method is only for those who don't mind drilling a small hole.
[Modified by Marcho Polo, 8:49 AM 10/16/2002]
Re: temp control door motor on my 90 (Marcho Polo)
[QUOTE]
Any chance of getting a copy of that diagram? I need to fix mine and I sure dont want to pull the box!!
I would rather drill a hole than to get back into tearing out the entire dash to get behind the heater core assembly to make the repair,
So can we get a diagram of where to drill this hole , pleeeassse.
Laura :sad:
Laura :sad:
Former Moderator
Re: temp control door motor on my 90 (PTz-92-LT1)
Okay, the area in question is in the picture at the very bottom. I have not done this yet, and since my heater core needs to be replaced, I'll probably never do this.... You still need to get under the dash area and remove two other bolts from the passenger footwell area, but this will keep you from pulling the whole dash apart to get the top bolt out. Here's an exact copy of what Jerry told me:
Flat Pack Motor
Right side cowl area below windshield.
Remove right wiper arm and screen.
10" to the left of center wipe tram. (?)
2 1/2" from inside cowl (back from front)
should be back in under w/s slightly
That's what he wrote... I'm not sure what "tram." stands for, but that's what he put down....
The hole doesn't need to be too big, it's either a 7mm or 1/4" bolt in there, so get that socket out and determine how big of a plug/hole you need.
Good luck! If anyone does this, please take pictures, I'd like to see.
Flat Pack Motor
Well I am needing to do this and I will take pictures, but be forewarned, Im the biggest computer dummy out there, so I feel sure I will be mailing them to you!!
Can you post some pictures of what the updated box looks like?
I just ripped my Ac box out along with the fan, shroud, water fill container, inner fender well, wiper fluid can, and support bar to the hood latch, to paint them. It took me 4 hours to get them out because of a round nut like piece that became unwelded inside the frame on the supprt brace. I had to drill out the bolt which took a lot of time due to it's location.
I would like to see what was done on the new cars.
Re: temp control door motor on my 90 (bill mcdonald)
There are several parts needed to complete this swap. I had to replace mine with the later model stuff when my clutch exploded tearing up all the ducts, etc. First you will need the box off a 1995-1996 model. It looks the same, other than the fact that the control motor is to be mounted on the bottom rather than the top of the unit.
You will also need the door that the motor opens and closes, as it has grooved shaft on one end for the motor to turn as well as a fin on one side that will keep the door from closing if you turn it upside down like I tried to do.
You will also need the harness to the motor from a 95-96 car or your heat/cool will be backwards due to the motor being flipped upside down. The part number for the harness is 12163192. I dont have the part numbers for the other parts handy or I would post them as well.
Re: temp control door motor on my 90 (91tpi-zf)
Please do sent the pictures. By looking at the description I'm not ready to perform this procedure yet.
I am not certain that a new harness is necessary. I talked to Gordon Kilebrew about this issue. Gordon said that when updating to the new box all that is necessary is to reverse the wires.
OK,
While at Carlisle, I got the box off a 94 and believe it had the new drop down style motor. With my luck, I probably got the wrong box. Does anyone know for sure if it's 94-96 or 95-96.
I also talked to Gordon with box in hand. As stated above, two wires need to be moved but Gordon said he would have to look at the schematics to make sure which ones to reverse, for the reasons stated above. A new harness sounds better. Thanks for the number. Then again, if all it took was a smalle hole, would probably go that route.
Former Moderator
Gordon told me '94 and up at the Cruise-In last May.....
