Big Inch High HP Induction
Old 01-01-2018, 09:08 AM
bjankuski
bjankuski's Avatar
I am not sure if this qualifies as big HP but here is my 406 (making around 525-550 flywheel HP) intake set-up on my Firebird.
Modified HSR, this was on my corvette before I went with a LS7 in the vette.
Old 01-01-2018, 12:03 PM
C409
C409's Avatar
..... Well that's an interesting upper air box ... not much stealth ram left there ! ... Nice ! .....
Old 01-01-2018, 12:14 PM
C409
C409's Avatar
..... BTW ... anything over 400hp naturally aspirated is big enough to be proud of ! ... I'm just curious about what's providing the intake air to the engines of some of our C4's ... anything creative that displays some thinking outside the box qualifies ... that means no stock TPI intakes ... polishing or powder coating is not creative from an air flow standpoint .....
Old 01-01-2018, 02:13 PM
Jagdpanzer
Jagdpanzer's Avatar
For us LT5 guys only alternative is to bore out the stock TB from 59mm to 63.35mm:
Old 01-02-2018, 09:07 AM
C409
C409's Avatar
..... Nice ! ... I always liked the "sophisticated" look of the LT5 engine ..... How much air does a twin 2 1/2" throttle Body flow ? .....
Old 01-02-2018, 01:39 PM
DVNCI
DVNCI's Avatar
Hogan on a 396 built by Jim B here on forum - haven't installed yet, hopefully soon!
Old 01-02-2018, 01:52 PM
bjankuski
bjankuski's Avatar
That is nice! What kind of power are you hoping for?
Old 01-02-2018, 02:16 PM
Jagdpanzer
Jagdpanzer's Avatar
Not aware if one has ever been flow tested.
However, I do know of several LT5s with increased displacement (415, 427, 441 CID) that are making North of 635 hp using the stock TB bored to 63.5mm. Cross section area of a twin 63.5mm TB is more or less equivalent to a single 90mm TB which flow around 1200-1250 CFM according to sources on the internet.
Old 01-02-2018, 02:42 PM
DVNCI
DVNCI's Avatar
Hoping for 800 or so with a Procharger F1A
Old 01-02-2018, 05:08 PM
C409
C409's Avatar
..... Cool ! ... What is the runner length ? and who spec'ed it ? .....
Old 01-02-2018, 06:24 PM
DVNCI
DVNCI's Avatar
Not sure, I bought it used off a guy.
Definitely longer than stock though!
Old 01-02-2018, 07:52 PM
JoBy
JoBy's Avatar
Modified Holley Stealth Ram and a small Turbo. Everything clears the stock hood. 372 CUI ( 4.125 bore, 3.48 stroke )
600 whp with 6-7 psi boost. More with 20+ psi.
Old 01-02-2018, 11:09 PM
  #33
383tpimachine
383tpimachine's Avatar
I have a lil hogan on my 400. Speced by Hogan for 7500rpm spinning and bungs for a nitrous setup with burst panel
Old 01-03-2018, 07:34 PM
  #34
C409
C409's Avatar
..... This is one of my attempts to get runner length under the C4 hood .....
Old 01-03-2018, 08:04 PM
  #35
dclafleur
dclafleur's Avatar
is that built on an offenhauser dual ram?
Old 01-03-2018, 09:56 PM
  #36
C409
C409's Avatar
.....Its an Offenhauser Cross Ram ... the top was available in a few different configurations ... single 4bbl , Tri-Power , and Dual Quad ... Edelbrock had a couple versions including the Smokey Ram ... and Chevrolet made one for the early Trans-Am racers ... THIS is the only Offy that I know of that is available in EFI ! ... I also had one of the Smokey Rams converted for EFI .....
Old 01-04-2018, 10:04 AM
  #37
dclafleur
dclafleur's Avatar
That's awesome I've never seen one converted to EFI (Hell most of the time I see them in garages waiting on a build that'll never happen).
To Big Inch High HP Induction
Old 01-04-2018, 10:33 AM
  #38
383vett
383vett's Avatar
Received 1,543 Likes on 1,043 Posts
Looks great. Jim is building a motor for a friend of mine. Great work. Great guy!
Old 01-04-2018, 10:37 AM
  #39
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
Now THAT is AWESOME. I love it! A port EFI crossram. Nice work! What were the results?
Old 01-04-2018, 02:36 PM
  #40
DVNCI
DVNCI's Avatar
Hey Willie!
Yeah I think I remember Jim telling me about that.
And yeah, Jim is great. Great communication, we spent a LOT of time just talking my motor through. He's definitely an asset to our community!
Quick Reply: Big Inch High HP Induction
