Grease points
Old 12-20-2017, 02:55 PM
Redbird
Support Corvetteforum!
Redbird's Avatar
2021 C2 of the Year Finalist - Unmodified
C2 of Year Finalist (stock) 2019
2016 C2 of Year Finalist
Default Grease points
How many grease points are there on a 93 Corvette?
Old 12-20-2017, 02:59 PM
PatternDayTrader
PatternDayTrader's Avatar
Received 1,056 Likes on 769 Posts
Depends on how many suspension and steering components have been replaced. If the answer to that question is zero, then I'm pretty sure only the ball joints were greasable. So four grease fittings.
Old 12-20-2017, 04:18 PM
mickey5
mickey5's Avatar
Tie Rod ends?
Old 12-20-2017, 05:32 PM
PatternDayTrader
Originally Posted by mickey5
Tie Rod ends?
I'm pretty sure the original tie rod ends are sealed.
Old 12-20-2017, 07:12 PM
DGXR
DGXR's Avatar
I am confident that all of my suspension parts are factory originals and there are 4 grease fittings, one for each ball joint. That is all.
Aftermarket tie rod ends usually have a grease fitting but not the originals. Strange but true.
1995 base coupe
Old 12-20-2017, 11:36 PM
Cruisinfanatic
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
there are 6 on my original 85
Old 12-21-2017, 08:37 AM
Redbird
Redbird's Avatar
Thank you guys. Just found the four originals.
Old 12-21-2017, 02:00 PM
70ZZ3 96LT4
70ZZ3 96LT4's Avatar
Default 6
yes on the 1985, just serviced the front end locations
Old 12-27-2017, 10:03 PM
Cruisinfanatic
Actually there are 8 fittings on early C4. 6 front and 2 back
Old 12-27-2017, 10:31 PM
WVZR-1
WVZR-1's Avatar
Received 2,271 Likes on 2,032 Posts
That's correct for the '85 and some other years! One of those things that ain't so difficult to count and visually check when servicing.
If less than OE spec u-joints are used for service it could change the count to as high as 14,
To Grease points
Quick Reply: Grease points
