87 starting issue
Old 10-02-2017, 09:44 PM
MedicR602
2nd Gear
MedicR602's Avatar
Default 87 starting issue
recently acquired 87 vette. Problems with starting. Have already drained the tank and put in fresh gas, replaced fuel pump, fuel filter and fuel pressure regulator. Getting correct pressure. Problem is wont cold start without spraying fuel directly into intake, runs rough then evens out after engine warms up. Also starts ok after engine is warm. Cannot figure out problem. Any one else have this issue? Don't know where else to look or what else to try.
Old 10-02-2017, 10:04 PM
86Pacecar
86Pacecar's Avatar
Well it sounds like no fuel during start up. Is the cold start injector firing? Are the main injectors firing? Get a "noid light" and see if the injectors are being pulsed.
Fuel, air, spark, check all 3.
Old 10-03-2017, 08:58 AM
Tom454
Tom454's Avatar
A lot of people eliminate the cold start injector using a kit. Check if your engine still has the cold injector installed. It should be on the drivers side intake.
MedicR602 (10-03-2017)
Old 10-03-2017, 09:12 AM
xrav22
xrav22's Avatar
Coolant temp sensor may play a role it is at the front of the intake.
Old 10-03-2017, 09:43 PM
MedicR602
2nd Gear
MedicR602's Avatar
didn't know about the cold start injector. will check it out and see. Thanks for the help.
Old 10-03-2017, 10:03 PM
jv9999
jv9999's Avatar
If they are the original injectors it might be time for new ones. E10 methanol gas raises hell with them.
Old 10-03-2017, 10:16 PM
aklim
aklim's Avatar
Received 2,260 Likes on 1,965 Posts
How does that work? He is having trouble starting and if you eliminate the CSI, wouldn't that, assuming it isn't causing the problem in the first place, make it harder to start?
Old 10-08-2017, 05:41 PM
Tom454
Tom454's Avatar
What I was trying to say is that the cold start injector may have already been removed. So he would need to reinstall it. This is usually a problem in cold climates. I honestly don't think it is the problem. It's possible, but not probable. Worth taking a look at.
Old 10-08-2017, 06:13 PM
aklim
aklim's Avatar
My bad. I misunderstood you. You might be on to something. Previous Owners, aka PO, aka Moron who owned it previously might have done something and forgotten about it. Ask me how I know.
To 87 starting issue
Quick Reply: 87 starting issue
