open rear hatch - no power.
Old 07-25-2017, 05:11 PM
Powerstroked89
Powerstroked89's Avatar
Default open rear hatch - no power.
Do C4's have a hatch release cable? I need to open the hatch, engine is out of the car. Dont want to cycle the key to accessories.
Old 07-25-2017, 06:59 PM
MikeP84
MikeP84's Avatar
My 84 does, it has a small cable under the plastic in the back
Old 07-25-2017, 07:37 PM
QZRBLU
QZRBLU's Avatar
2017 C4 of Year Finalist
No need to "cycle the key", simply connect the battery and you should have power to the hatch release buttons. Just ensure the battery cable at the starter is well insulated.
Old 07-25-2017, 09:00 PM
MikeP84
MikeP84's Avatar
You could also just do that /\ just make sure you pull your fuel pump fuse or you'll have gas every where!
Old 07-25-2017, 09:23 PM
Benny42
Benny42's Avatar
There is a small steel cable under the carpet just below the hatch mechanism. Grab it with pliers and pull. I've pulled an engine in one of these, no way would i tape off everything and connect a battery.
Old 07-25-2017, 09:31 PM
MikeP84
MikeP84's Avatar
Probably could connect all the grounds to the battery and ground to frame but I would just play it safe and pull the cable
Old 07-26-2017, 02:27 AM
Cliff Harris
Cliff Harris's Avatar
This should be enough to get your hatch open:
kenmohr (07-27-2017)
Old 07-26-2017, 06:42 AM
Joe C
Joe C's Avatar
I personally would not cycle the key. the ECM is grounded to the engine block (via the LH cylinder head). applying power to the ECM without a ground will damage some functions within the ECM itself. electrons are funny - they WILL seek out another path. don't let the metal case of the ECM fool you - that case is not a chassis ground, as I found out. spoken with real "dumb-***," hands-on experience!
to be on the safe side, just pull the emergency release cable.
To open rear hatch - no power.
Quick Reply: open rear hatch - no power.
