connecting wires together
Old 08-06-2016, 11:22 PM
bullguts
bullguts's Avatar
Default connecting wires together
MAF sensor connector and pigtails
hi guys just ordered this and just wondering what the best way is to connect the wires together in the engine bay , Cheers and thanks in advance
Old 08-07-2016, 12:22 AM
mtwoolford
mtwoolford's Avatar
western union splice, solder and shrink wrap
bullguts (08-07-2016)
Old 08-07-2016, 12:31 AM
Joe C
Joe C's Avatar
typically, I use a type, or variation, of the linesman splice - solder, and shrink sleeving. try google - plenty of examples -
Old 08-07-2016, 12:38 AM
bullguts
bullguts's Avatar
ok , thanks for that and was actually thinking along those lines but, there seems to be a wide range of connectors out there . Some actually say that , solder is not a good conductor and heating the wire makes it brittle . Cheers
Old 08-07-2016, 01:30 AM
Joe C
Joe C's Avatar
Originally Posted by bullguts
...some actually say that, solder is not a good conductor and heating the wire makes it brittle. Cheers
- you better research that before taking that statement at face value! granted, solder is less conductive than copper wire, but any resistance caused by a soldered joint is negligible. you probably have more error in your multi-meter, than what you can read across the solder joint. nothing to worry about. the quality of the splice is dependent on the "mechanical" connection (in this case, WU or lineman), and the solder. a good, quality, solder, made for electronics is a must, and I personally use kester44 rosin core 60/40. the statement about heating wire/solder and making the wire brittle is nonsense. even NASA uses this method for splicing wire.
The following 2 users liked this post by Joe C:
bullguts (08-07-2016), ChrisWhewell (08-09-2016)
Old 08-07-2016, 07:27 AM
ddahlgren
ddahlgren's Avatar
Solder is not your friend with anything subject to vibration. Brased seam uninsulated butt splices a proper W form crimper and heat shrink with glue inside it.
Old 08-07-2016, 08:20 AM
WVZR-1
WVZR-1's Avatar
Received 2,266 Likes on 2,027 Posts
In these times I'd go with this technique vs most any other. In the 80's/90's I'd likely have used the Delphi splice clips shown in the FSM for the C4's. I've used many/many of them.
I believe that a GOOGLE search for "Environmental Splice" will get you appropriate information. A five wire also has it's challenges - stagger the splices in a reasonable range. Add "aircraft" to the search term maybe.
The correct crimping device is important
Had you not already ordered I'd suggested maybe a connector shell and terminals BUT the one you imaged has it's own challenges. It's "pull to seat" and you can't release and insert, you need to pass the wire through first, add terminals and then pull back into the shell. I wouldn't have a problem with it because I've done them. Correct crimping device required again.
Old 08-07-2016, 11:06 AM
s carter
s carter's Avatar
We always used the small Crimp Clamps, Soldered and Shrink Tube That Oozed sealant from the Packard Electric Splice kit.
Old 08-07-2016, 11:57 AM
ChrisWhewell
ChrisWhewell's Avatar
I strip the ends of each a pretty good length, slip a shrink sleeve over one side, then twist braid the two wire ends together so they're linear, touch it with a solder iron and let the solder flow through the wrap. Then, one wrap of electrical tape and then slide the heat shrink sleeve over it and hit it with the effluent of a propane torch, not the flame part, just the hot air. Probably a crimp sleeve is quicker, but my connections never fail until after I'm in the ground
Old 08-07-2016, 08:51 PM
Joe C
Joe C's Avatar
- that is probably the best way to go. from a google search, "environmental splice aircraft" here's link for splices and a "proper" crimping tool. along with the 5 butt splices, it shouldn't set you back more than a couple hundred bucks -
http://www.aircraftspruce.com/catalo...ptoolgm232.php
no flames, and not to be a wise ***, but seriously, (and to the OP) don't over think this, and use the KISS. approach - strip the wire, lineman twist, solder, and shrink sleeving. as far as "solder is not your friend with anything subject to vibration," not sure where anyone's going with that. secure the harness repair on both side of the splice(s) with a couple tie-wraps. this isn't a mission to mars -
BTW, just my 2-cents....
Old 08-08-2016, 01:23 AM
STL94LT1
STL94LT1's Avatar
Here's a different spin. Can you re-pin the new connector? No splicing needed.
I work at a GM facility. Soldering is not a GM approved repair technique. We only use heat shrink butt splices.
bullguts (08-08-2016)
Old 08-08-2016, 04:24 AM
bullguts
bullguts's Avatar
to be honest this the second time around for me , first time around bought the connector shell and pins and crimp the wires onto them , type of deal . I obviously failed dismally doing it that way because it all came apart when I pulled the sensor off . Tried soldering the pins to the wires and ended up breaking one of the pins . Lesson learned , and thanks to every one for your help , cheers .
Old 08-08-2016, 05:36 AM
WVZR-1
WVZR-1's Avatar
i looked a little closer at the connector image and it's likely a Delphi 150.2 and NOT a "pull to seat" like I mentioned earlier so I'd likely suggest the shell, terminals and seals all over again but maybe borrow/buy the crimping device or maybe just hire the assembly. Since you hinted the pig-tail is already ordered just do the cut splice whichever way you think best.
I doubt "JoeC's" comment of a "couple hundred bucks" is required for the "Environmental Splice" BUT if you own an older C4 sooner or later quality cut/splice and electrical connector assembly is going to be required. Quality tools makes most much easier.
Do you have issues with getting parts in your location?
Old 08-08-2016, 06:08 AM
bullguts
bullguts's Avatar
This is where I was at , when the fifth pin broke and i'd already soldered the others on . so almost ready to go , then could not purchase another pin , being a bit too oddball . All the C4 parts I get have to come via USA , and i'm in Australia so it usually takes a couple of weeks . Any how thanks , cheers
Old 08-08-2016, 08:23 AM
arbee
arbee's Avatar
I work in heavy industrial construction and have for 25 years. In all that time, I have only seen a soldering gun being used once or twice, and that was for very specialized applications where crimping was not practical.(applies to PC boards etc.). As I speak, we are completing a cement processing facility involving hundreds of instrumentation, power and PLC terminations. Not one piece of solder. Soldering is old school and rarely used today. However, there are people on this board that will never be convinced of this fact.
Old 08-08-2016, 08:38 AM
ChrisWhewell
Solder can't be all that bad, they use solder on the circuitboards in the ECM, ICM, Radio, climate control, etc. Crimps are faster, and profitability depends on labor costs, that's why crimps are used, they're "good enough" for now. Imagine building a radio and crimp connecting every component in the circuit, instead of using solder, lol
Old 08-08-2016, 09:03 AM
Joe C
Joe C's Avatar
old school, yes - well maybe, but "tried and true" still applies. there are still a bunch of people doing "old school" - just google "approved solder splicing wire." while there may be better, more current methods for repair, we're talking about a 5 wire, electrical connector repair on a 25 year old car, not some heavy industrial equipment or a processing facility with a bunch of high tech stuff. no flames, but some people tend to make things way more complicated than it needs to be, while others try to impress us with their technical expertise -
I think ChrisWhewell nailed it in his post - "crimps are faster, and profitability depends on labor costs." besides, less gray matter involved -
OP - keep it simple - crimp, solder, or whatever. fix the thing and move on. this ain't rocket science (or a dump truck)!
To connecting wires together
Old 08-08-2016, 01:02 PM
arbee
arbee's Avatar
Sorry Joe C, I have no need to impress anyone with technical expertise - it is simply fact. Don't take my word for it, check any numerous websites. Google is there for everyone. Several industries ban solder because under certain short circuit conditions, a solder splice can melt whereas a crimp will not.
Old 08-08-2016, 02:07 PM
Joe C
Joe C's Avatar
...and what industries would that be? not to doubt your "technical expertise," but reference NASA-STD-8739.4A – 2016-06-30, page 70, section or paragraph 19.7 -
http://www.hq.nasa.gov/office/codeq/...NSTD87394A.pdf
but then again, our space program is kind of backwards. .
if anyone experiences a "short circuit" condition that would cause solder to melt, the melting solder would be the least of their problems. I'm sure you know all about current limiting and circuit safety devices.
Old 08-08-2016, 02:33 PM
arbee
arbee's Avatar
OK. You are far more knowledgeable about this than me. Last sentence in my first post is proven.
Quick Reply: connecting wires together
