Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-11-2002, 10:53 PM   #1
x_streme
CF Member
x_streme's Avatar
Default OK I'm stumped, why is oil coming out the top of my dipstick?
It is drving me nuts, and it's a lot of oil too. :mad There is some oil smoke coming from the exhaust, could it be conected?
Thanks as always, you guys rock!
x_streme is offline   Reply With Quote
Old 09-11-2002, 11:08 PM   #2
yoslambo1@cs.com
CF Senior Member
yoslambo1@cs.com's Avatar
Send a message via AIM to yoslambo1@cs.com
Default Re: OK I'm stumped, why is oil coming out the top of my dipstick? (x_streme)
post this on engine mods im sure someone will know.good luck! :cheers:
yoslambo1@cs.com is offline   Reply With Quote
Old 09-11-2002, 11:13 PM   #3
0ski_dwn_it
CF Senior Member
ski_dwn_it's Avatar
I hate to break the news to you fella. But I just posted on another exact post just like yours. I will tell you the same thing.
My car when I bought it was doing the exact same thing. I took care of the leak with a bandade of sorts. I wrapped the top of the tube with electrical tape which made the dipstick fit very tight. Solved the problem, but there is more to it than just that. The reason you are getting excess oil up through the dipstick is the rings in your car are more than likely leaking. I took mine to a shop and they diagnosed, basically confirmed what I was getting for leakdown. My car on the other hand, never burned an onze of oil, but the compression was leaking down past the rings, causing the crankcase pressure to be excessive. Too much for the breathers to handle, therefore the dipstick was being used to vent the excess.
Have your car leaktested or buy a tester from Summit. You will most likely see what I am talking about. If your burning oil, your are probably worse than even mine, which were pretty bad. 20% on some and one was 50%.
You would have never known by driving my car, the reason I started looking was my 1/4 mile trap speeds were about 7+ MPH off. They were only ~104-105 when they should have been 110-113 MPH.
I hope I am not right, but I think I might be. :(
ski_dwn_it is offline   Reply With Quote
Old 09-11-2002, 11:16 PM   #4
sinistervette
CF Senior Member
sinistervette's Avatar
Possibly. Have you pulled the oil fill cap with the engine running? If so, does it seam to have smoke, air, or oil coming out? It could be the rings are giving out, causing blow by and excessive crankcase pressures :sad:
Have you checked the pcv valve? This could also be bad and cause part of your problem. Good luck. :cheers:
sinistervette is offline   Reply With Quote
Old 09-11-2002, 11:23 PM   #5
x_streme
CF Member
x_streme's Avatar
Default Re: OK I'm stumped, why is oil coming out the top of my dipstick? (sinistervette)
Nuthin comin out of the oil cap with it off, a slight amout of oil seeps from the fill cap when its on.
new PCV valves, thought that may have been the problem, but it's not. I am also getting some oil in the throttle body coming from the right PCV valve.
I was afraid i poped a ring, I will have to have a leakdown done.
Old 09-12-2002, 07:56 AM   #6
cajun86
CF Senior Member
cajun86's Avatar
BLOW BY :sad:
cajun86 is offline   Reply With Quote
Old 09-12-2002, 09:01 AM   #7
0ski_dwn_it
CF Senior Member
ski_dwn_it's Avatar
Default Re: OK I'm stumped, why is oil coming out the top of my dipstick? (cajun86)
yepper the oil in the intake was pretty obvious in mine too. That can also lead to knock from the hydrocarbons.... good luck :(
Old 09-12-2002, 10:04 AM   #8
Denney
CF Senior Member
Denney's Avatar
Quote:
BLOW BY :sad:
Yup, most likely... Click the image to open in full size.
Denney is offline   Reply With Quote
Reload this Page OK I'm stumped, why is oil coming out the top of my dipstick?
Tags
coming, dip, dipstick, oil, oild, stick
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
