1995 LED interior light upgrade
Has anyone tried upgrading the interior lights on a late model C4 to LEDs? I tried replacing the lamp in the door with a LED equivalent and started getting odd behavior with the lighting circuit (lights turn on initially then get temperamental about turning on again). I have had a few problems with interior LEDs in other cars due to the small current draw which may be confusing a lighting controller. This is similar to installing LED turn signal bulbs in the front or back and getting a rapid flashing interval (hiperflash) because they don't draw enough current to heat up the bi-metal strip in the flasher.
Before I invest in all the bulbs for the interior, I would like to find out if anyone else has had any luck good or bad.
Thanks,
Chris
Thanks,
Chris
