May need to Nomex-up for this post, but...
Also a long-time Porsche guy, and have "back-dated" a number of cars to reduce weight/complexity, etc.
Considering building a (different) LT1 car into a very simple, lightened street car with no radio, AC/PS, etc. Am used to driving some pretty gnarly cars so the lack of civility is not an issue.
Thinking of going with a carbureted rebuild of the LT, and wondering what can be done to convert from the Opti to dizzy (or other system).
Any ideas/experience with this?
.....long-time Porsche guy..........Considering building a (different) LT1 car into a very simple, lightened street car with no radio, AC/PS, etc. Am used to driving some pretty gnarly cars so the lack of civility is not an issue.
Plenty of race car/track cars have done this.
These cars are plentiful and cheap, so no worries hacking one apart...if you start with something that is relatively rough to start with, don't start with a museum piece. ;-)
I've enjoyed the fabrication journey with mine. Post pictures while you progress!
Supporting vendor David Frederic converts LT manifolds to accept conventional distributors. There are also aftermarket intake manifolds that mount a conventional carb atop an LT block; these could also be modified to accept a conventional distributor,
I like you're desire to simplify the engine / vehicle, good luck.
idk if they do it for LT, but crank trigger might be another option that might cost the same or less in the end.
I've pulled about 400+ out my 86 so far and it's street, still PS but not gonna be forever.
This for drag or road?
This will be a street car, with very occasional driver's ed./road course days. Would you happen to know if there is a good PS delete kit for C4's?
I started with an '88 Z52 that had frame braces etcetc and I elected to keep fuel injection on mine. I learned to do my own tuning and everything has worked out fine. I like the LS conversion but mine won't be going that route. I like the quickness and affordability of doing a local normal SBC rebuild. I've posted many pictures and started a lot of threads. I'll include a few pix here.
Thank you! It's been years in building and I should get some updated pix. I removed the mirrors, heater core, and wipers, last year. It always amazes me how long brackets take to make!
This is the only kit I've seen and it's more for drag I think http://www.jd2chassis.com/c4_rack.html Some on here have had a custom fab job done. I drag so idk bout the steering needs of road.
edit: almost forgot cool vid Aardwolf, I pmed you awhile back about an old post of yours if you could check your pm's
PM about the stock cam? I haven't changed them at all just replaced.
I kept power steering on mine but added a cooler and Redline fluid. The Hoosier's on there now are over a foot wide and it is tough to turn the wheel without the car on.
Think Boot had PM'd you previously if I'm reading his reply correctly...
