Brake dash warning light
I understand the "SHOULD BE" for sure.
Got a vacuum pump bleeder from Harbor Freight and bled all wheels again. Got a better pedal of brakes but the light is still on. One possible problem I did see was that the right front when bled took a long time to get fluid to flowing. The rest of the wheels filled up the pump container with fluid rather quickly with the vacuum pump pressure declining slowly. The RF pump pressure went down quickly with very little fluid flow. I have never had any problems with the brakes pulling either way but this fluid flow is confusing.
Also are there any other bleeder besides the 4 wheels?
Sounds like your rubber line is swelled up constricting the flow might be time to change them. Any sign of leaks?
Need a new bleeder I would think you got some air in there swapping them.
#34
One thing new I did see. I have all 4 wheels off the car - makes for easier bleeding. I cranked the car and put it in drive. The front wheels locked down but the rear wheel will not lock down unless you really stand on the brakes.
Evidently I have unequal pressure between the front and the back but what is causing it? MC has been bled twice. All wheels have been bled at least 5 times.
Could it be the proportioning value in the MC causing the problem? If so how would you check it?
This is a new Cardone Select MC from Rock Auto.
#35
The front wheels need to be turning for the brakes to work right. Does the piston move off place each time the light comes on?
#36
#37
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
The switch needs to be removed and once removed you can access the pressure equalization piston. This small piston needs to be centered in the master cylinder housing. Bleeding moves the bias switch forward or back. Move this small piston to the center and reinstall switch. The warning light will go out.
Pull the switch and look into the hole. The shuttle piston has a ring groove that should be centered. The switch has a small pin that rests in this groove. If the shuttle moves from a drop of pressure on one side the shuttle pushes up on the switch. If the o-rings on this shuttle leak. Fluid comes out of the switch.
#39
Looks like the problem is found! I have never personally messed with one. Hope someone can tell you why.
#40
BINGO!
Another MC??
