Anti freeze leak ?
Anti freeze leak ?
My car seams to be leaking anti freeze but I can't seem to find where the leak is. The hoses are dry, the water pump is also dry. I did find some anti freeze on the drivers side rear of the engine block. I removed the scatter shield and it is perfectly dry and no issues there. Could I possibly have a head gasket leak and if so what are my option. The engine is original with 12K original miles with aluminum heads.
What is the year of your vette?
12K miles?
See if this info helps:
http://www.benplace.com/pressure_test.htm
12K miles?
jimfed (04-19-2016)
His avatar shows what appears to be a yellow '86 Indy Pace Car (door decals).
A head gasket leak is a possibility. By "scatter shield" do you mean the inspection cover at the bottom of the auto trans bellhousing? Coolant in there could point to a leaky freeze plug at the back of the block. Did you look at the block freeze plugs below the cylinder head?
You might want to get a cooling system pressure tester (AutoZone will have them for rent) and put something like 16-20 psi of pressure in the system. Then look for any leaks.
jimfed (04-19-2016)
Pressurize the cooling system and listen and look for the leaks. I had a leak that turned out to be the hose that goes between the TPI and block behind the waterpump. I did find one thing that might help. Quite by accident after fixing that leak I was using a black light to see if I could see anything on a AC freon leak (looking for the dye). It showed the remnants of the coolant leak (didn't expect that). I don't know if you can rent them, but you can get a cheap battery black light flashlight off ebay for $3-$4.
Hope that helps.
jimfed (04-19-2016)
12K miles?
12K miles?
Hope that helps.
Intake manifold gaskets are known to leak coolant on L98's.
jimfed (04-19-2016)
If the leak is near the driver's side rear of the engine block, I would check the following: Inspect the area where the head meets the block at #7 cylinder. If you have the optional engine oil cooler (KC4, I think), check the hoses going from the cooler to the metal cooling pipes and all around the oil filter. A pressure tester may help expose the leak, but if you have a working radiator cap, it probably won't make a difference. Drive the car til it's warm then park it over some cardboard.
jimfed (04-19-2016)
My 85 had the same problem and I could not find the leak. Well the water pump let go and I thought that was it. Turned out it was the water pump gasket driver side. You might also look at the heater valve on the passenger side, I had too fix that back a couple of years ago.
jimfed (04-19-2016)
I had a very slight coolant leak on my 91. I could not see anything obvious until I took a flashlight and one of those extendable mirrors and had a look around. I found the underside of the throttle body coolant bypass hose was wet and leaking. You might check that as a possibility.
jimfed (04-19-2016)
GM used a steel manifold gasket with aluminum heads and manifolds in those years. It creates and electrolysis at the water jacket ports. Could be any of the other comments above but I've had this happen to me. Make sure and replace with FelPro blue should this be the problem.
jimfed (04-19-2016)
