Modifying K member on the drag car .. Pics
Hey guys ,
in the process of updating my front suspension with some pretty unique stuff .. The K member was cut , braced and a new stiletto rack was installed . Next step i will be replacing the complete front brake assembly with Strange drag race setup using billet hub assembly ..Stay tuned if interested . Thanks
Looks great. Those Stiletto racks are top of the line. Keep up the good work.
Looks great!
Did you happen to weigh the old and new parts? I have contemplated replacing some of the braces with lighter tubing.
My buddy just got done machining the spindle and modifying brackets to fit the Strange brake kit ... No more factory hub assembly, it's all billet aluminum that can be rebuilt as needed .
I honestly did not , but i do have the 4 corner weight for the car before and will be scaling it afterwards .. The new brake setup should be close to 10lbs per wheel and the rack was only 5lbs vs the stock one that was close to 15lbs .
