Took the new vette out today! Probably will be putting a clutch in it soon though
Temp was about 55 today in Rochester NY so I went and took my new to me 94 out of storage and brought it home!! When I put it away there was a little bit of clutch slippage. When I drove it today it had about the same amount and it seems to get worse as the car warms up. I was hoping I would get lucky and maybe replacing the hydraulics and whatnot might give it some life but I don't think so anymore. I stopped by my uncles house around the corner a little bit later and left the car running in the driveway for a little bit (enough for the cooling fans to come on) and when I left there was almost no clutch at all
I noticed back in December when I bought it that when it cooled down or sat overnight the clutch would get better but this was the first time I was driving the car and it got to full temperature
Anyway, I do have a clutch question. Rockauto has a kit with a solid clutch and pressure plate (part 04142) that I might go to as my replacement. As long as my flywheel is not totally cooked when I get in there I plan to reuse that.
Call me a dreamer but I still plan to replace the hydraulics and look for other problems before I do call this clutch totally toast
Is there any oil dripping from the bottom? If it slips after warming up I would be concerned that maybe the rear main seal is leaking, either way your going to have to drop the gear box out and take a look. I wouldn't suspect any hydraulics unless its been converted to a push type hydraulic TOB. In stock form the slave cylinder is outside the bellhousing and couldn't leak onto the disc.
If the rear main is leaking I would think removing the inspection cover on the front of the trans would be sufficient to see the leak
Your symptoms seem to indicate a worn out clutch. Before you dive into this project, read some of the many threads on changing over a stock dual mass flywheel to a single mass flywheel. good luck
After sleeping on it, I've come to terms with reality. I plan on putting in a stock replacement clutch and pressure plate for now and using my original dmf. If I'm not happy with the a stock replacement then next summer I'll source a stage 2 clutch and components. Should be a fun project I have access to a lift with trans jack and everything else I will need so hopefully all goes well.
I think I will order the stock replacement kit from Carolina clutch. Does anybody have any other places they prefer to deal with for these parts?
Thanks all!!
Thanks all!!
Thanks all!!
Thanks all!!
Thanks all!!
Thanks all!!
Thanks all!!
Thanks all!!
Thanks all
Thanks all!!
Thanks all!!
