completely died with out warning at 80 mph
Old 02-10-2016, 12:07 PM
Dano86
Dano86's Avatar
Default completely died with out warning at 80 mph
Greetings all!
My ’92 with the LT-1 has developed an issue that I am not at all sure what it could be and I am hoping that someone else has gone through the same issues.
My car is acting like it has a misfire but that is not the case after close inspection. Recently I was driving down the interstate at 80 mph and my vette completely died. Only way it would start and keep running was is with the throttle held slightly open. After restarting it did it again about a half mile down the road. Then sitting on the side of the road for about 30 min letting things cool down it started up and made it the rest of the way home about 10 miles without issue other than the misfire like symptom.
Does anyone here have firsthand knowledge with this issue? I am not sure where to start because it will start in the driveway no problem but it idles similar to what you would expect with a misfire. After pulling all spark plugs (still connected to wire with assist of another to check them) one by one there is no issue with spark. That and I would not expect just a misfire to completely kill the car while driving down the road?
Thanks in advance
Dano
Dano86
Dano86's Avatar
posting in general forum also
Old 02-10-2016, 01:17 PM
antfarmer2
antfarmer2's Avatar
One post is enough take your coil and icm in and have them tested. Do a fuel pressure test as well.
Old 02-10-2016, 07:17 PM
1993C4LT1
1993C4LT1's Avatar
Do you know how to scan for codes? Put a paper clip in pins A and G in the OBD1 connector. Don't start the car, just put the key in the ON position. I would start there. If none, follow ant farmer's post.
Old 02-10-2016, 08:36 PM
Silver96ce
Silver96ce's Avatar
As Antfarmer said, have the coil and ICM tested. Also, how many miles on the car and how many on the optispark? It may be failing.
Old 02-10-2016, 10:14 PM
pcolt94
pcolt94's Avatar
Fuel pressure can be fine at the house when all is running but consider this.
When was the last time the fuel filter was changed?
This is a symptom of a clogged fuel filter. The car can run fine at lower speeds but at higher speeds is where fuel demand and flow is greatly increased and is where fuel starvation will occur. Fuel pressure will decrease and it could take a while till the fuel plenum is filled with fuel again.
Old 02-10-2016, 11:40 PM
BV85
BV85's Avatar
That happen to me on my 85. I know it's not an LT1 but turn out to be the fuel pump. Hope this little info helps you.
To completely died with out warning at 80 mph
Quick Reply: completely died with out warning at 80 mph
