Should I pull the trigger?
Just got a 383 shortblock quote from Golen Engine Service. Now is the part where you have to decide how much you want to give your cash a new home. :)
1-Piece Rear Main / Rollercam 350 Block
Eagle 4340 Forged Crank
Eagle 4340 Forged H-Beam Connecting Rods
JE Forged pistons
Speed Pro Plasma-Moly Rings
Block: Thermally cleaned and Stainless-Steel Shot. Inspected by MPI process. Bored, honed and pressure washed. Clevite cam bearings and pioneer brass freeze plugs installed
Block Preparation
The block is visually inspected and MPI (Magnetic Particle Inspection) tested for casting flaws and/or cracks. It is then bored for oversize pistons using a custom-built Rottler FA2-AVB automatic precision boring machine. Finish sizing is accomplished using a state-of-the-art Sunnen CV616 power stroke honing machine.
I was quoted this being good up to 750hp and 8000 RPM if I ever needed it.
[Modified by scorp508, 12:06 PM 8/30/2002]
JE Forged pistons
Block Preparation
Re: (scorp508)
How much??
$3500. If I give them $1000 deposit tomorrow it will be done in 1.5-2 weeks.
Re: Should I pull the trigger? (scorp508)
There is nothing wrong w/ this combo. Is there a Q here?
These parts are more than strong enough for an NA task. You could spray this combo if you wanted to.
You could do it for less $, but time would be a factor.
Is there a Q here?
Scorp repeat after me...............YOU ONLY LIVE ONCE!!!! :)
Received 1,401 Likes
Buy it. :yesnod: :yesnod:
Re: Should I pull the trigger? (MrJay)
How much with a cast crank? Do you really NEED all forged internals?!? That is a lot for just the bottom end...
