434 vs 383 build
Sorry I was comparing the price of a 383 vs 434.. for around $350 difference.
You can do a start button around $150. Get a Spal or equivalent (speedway or FLEE BAY) shaved door kit without the "poppers" to push open the doors. The kit comes with remotes, solenoids, receiver and other parts you need. Get 3 relays. Hook #1 relay into the door open wire so it locks on when powered by the wire. It allows power to the start relay and button which locks on when the button is pushed, also powers the coil. De-energizes the #1 relay. #1 relay when off allows the start button energize #3 to open the #2 stopping the engine.
Can be done with 2 relays but wiring gets a little complex for some.
I did it on a friends rat rod a year ago.
My only fear of computers is when the module becomes obsolete and unavailable - like in a C5 temperature control module. We had a few machines that were still good but the controls were bad.
Both sides are fun.. I just want to go simple..
Most Carb problems are PVC related, most replacement PVC valves don't resemble the original in specks. Flow to much at the wrong times. I can start my 1980 Chevy in 5 degree temps, turn on the radio and go.. Usually late for work.. . I run the electric choke off a temp sensor in the water jacket.
Other blocks are larger ci sbc than dart. Motown 454sbc
I can't believe $350 difference. Are you talking the dart block, or the little m Chinese knock off?
The PO added a "security feature". A push button start below the key area or a flat surface parallel to the ground. IOW, he was too lazy and stupid to fix the relay melting issue and hooked up a push button switch. The setup you mention. How does it work? Sounds like there isn't a transponder in the key fob that signals the car to ready itself but relies on the door being closed to energize the circuit.
Mercedes used to engineer their cars to last forever. They even give out mileage badges to attach to your grill at 250K, 500K and 750K kilometers as verified by the dealership. At 1 million miles you get yet another badge. When I had my 99 E300 verified at 500K kilometers, I asked how many they had given out. The local dealerships basically gave me a blank stare. Seems like MB had changed the strategy to a much shorter lifespan, aka disposable car. 10 years after 2001, my Excursion now has the "NLA" (No longer available) or "Obsoleted" on parts that are Excursion specific. Sucks but that seems to be the way of the future. The Zippo is done. Make way for the Bic.
Not sure why but one theory is that it is simpler for me to deduce what is happening from a readout than to rely on subjective feelings like smell, feel of the engine, etc? Maybe when it is a carb, I don't know what it is doing whereas with a computer, I can get readouts and am pointed in a direction? IDK. Just a theory.
I believe some of Dad's cars were carbed and they seemed to run kinda rough when it was cold out and after warming up, seemed better? I know my yard stuff definitely does run that way. Start it with choke, ease off the choke when it gets warmer? At least that was how I saw Dad do it in his cars and seemed to work.
The start button works off the open circuit for the door lock solenoid wire which energizes the #1 relay. When you push the fob the receiver energizes the door open circuit ( if you have door poppers the door swings open) It's not the best but is cheep and works well.
For a few more bucks, a fob and receiver with a trunk button can be used for the start circuit. ( I assume you want auto lock and unlock for the doors off the fob)
The low riders / rat rods use the trunk circuit to pop the hood and energize the electric lifts to open it.
The kits are available with up to 6 channels on the fob, just have to pay a lot more. Just look on the lead sled and low rider sites..
I'm not afraid of computers and have worked with them most of my working life as an R & D engineer. On the new equipment we had and on the new machinery there were computers, sometimes we wondered why?. The computer machines were more "efficient", but the old machines never stopped. Both sides of the coin have advantages and draw backs..
[COLOR="DarkRed"] To me it's like the push button start, you still hace a "fob" - now where do you put it, with a key you hang it in the ignition lock.
And as far as computer controlled machines, in the R&D world, some manual machines are great. But for me, as a Manufacturing Engineer, that wants to keep manufacturing parts in the USA, I need those computer controlled machines to make parts efficiently, and cheaper then what can be sourced from China. Our little shop produces over 3/4 of a million machined parts per week, can't do that on manual machine...
Received 3,043 Likes
St. Jude Donor '05
On ci builds they are never cheap. 427/434 is going to be a riot on the street any way you slice it.
I remember hearing about that. They built their rep in the 70s and 80s and have been riding on that forever.
Couldnt give me a MB. Girl has a 00e320 with over 200k weve hardly replaced anything imo just a lucky strike. I cringe to think what its gonna cost when something (like a trans, over 4k) goes.
First off, MB isn't Government Motors that screwed itself so badly that it had to beg for a bailout and accept a new CEO who got Obama's nod. Secondly, your Girl's record is not that bad but kinda low to me because we have a 99 E300 which is still a W210 chassis with 458K on the clock, Junior. I have spent way more money on salt damage. Trans is still original, fixed the Spring Perch which is a known issue when you have salt, AC done once, heads pulled when we allowed galvanic corrosion to take place between the head and the glow plugs at 300K and we rebuilt the head. So all in all, I don't think we did too badly. 7000 miles more to the 750000 km badge. The best part? I hardly hear the phrase "No Longer Available" or "Obsoleted" at the parts counter. So, if you have 200K and you blow a $4000 transmission, what exactly do you think it owes you? I break GM transmissions at under 100000 miles.
I ran the start through the neutral safety , no steering column lock on a rat rod.
The show cars have many items hooked to the fobs. windows, lights. hood, trunk all listed on their specialized sites...
If I did it for myself I would just go with a DTDP + momentary on SP push button and call it even. The switches are hard to find. They were used on the old gas generators.
St. Jude Donor '05
Thing is when it goes guess whos gonna have to pay to fix it?
GM 4l60e.....going on #4 or 5 in my Silverado lost count. I would never buy a new car even an import. We drove a few hondas, toyotas etc I was shocked was pos they are putting out now for the $.
Old stuff for me from here on out I can actually fix
Ex...I need cats for my truck. $1300 min for GM stuff aftermarkets barely lasted me a yr. Solenoid for a MB (and they have a zillion) can cost hundreds per.
It owes zip, even the mechanic who corrected a software issue (got stuck in 2nd auto fwiw) said get rid of this thing hed never seen one go 200k)
When it goes, you decide if you want to fix it. I fixed both spring perches thanks to salt on roads and MB comped me half. Oh before I forget, I changed the seat heater on the driver side. Would I spend $5000 to fix all the rust? Nope. Car isn't worth it. I bought it in 05 March and put 400k on it. Exhaust is rotting but not worth it.
Why shocked? Things go up in price from when you were young. It is par for the course.
No, I'll let people like you and my wife play "what if". Odds of that many failures is very rare. At this rate we can speculate on a complete wire replacement and what it costs too. A poorly diagnosed car means lots of replacing of parts. I tend to be involved in the fix and I want to know the game plan. I don't just write the mechanics a blank check, no questions asked.
I feel your pain with the CATS.
I'm going through the nonsense with the wife's dog car - Ford Escort wagon. Went to Auto Zone free computer readings. The computer said bad O2 sensor, it was new, went old school and used sparkplug light to find the 2 hole on the coil pack dead. Replaced the coil pack, plugs and wires ran better no miss, low power - no codes. Swapped the O2 sensor - under warrantee, no change. New code for temp sensor, swapped with one from a good car (friends car), no change. His car ran good with the sensor. Took it to the shop, it's been at the shop for 3 days now - they still don't have an answer. Runs good then starts to loose power and miss, then back to ok.
Her Subaru, 27k miles had to replace the 2 up stream heated wide ban sensors cost me $370 for the pair. Evidently since the car sat for 8 months it is a common issue.
My 1980 Chevy truck at 450k miles the carb finally went, due to the Alcohol in the fuel eating the metal. Figured time to replace the manifold and go Aluminum. Carb + manifold w/ gaskets = $425.00. (free air cleaner and hat) Took me almost the entire Saturday afternoon. Truck is running great again, did it 2 summers ago.
Trans failed at 275k miles, rebuilt for $450.
I agree old school is cheaper to maintain.
#34
Love the picture, that is the proper attitude for a C4.
I'm currently running a 383 that is getting tired and has started to have oil ring problems. I also broke a valve spring so it's time. The motor ran up to 4k rpm, scary but weird. ( have not pulled the heads)
I also currently have a Richmond 6 speed behind it. 330-17 tires.
I was looking for the occasional blast, running at the airport : not drag track days = no slicks.
So hopefully the rest of the power train will hold.
The Skip - white build is close to the GM crate in price ,, that is why I'm thinking 434 stage 2 or 3.
Just wondering how it will live on the street.
#35
My snowblower runs "funny". IOW, I have no clue what is wrong. Change wire, carb, plugs and a couple of other parts and you are out of parts. I don't need to have a brain to "fix" it. Exactly what the mobile repair guy said. Rebuild carb, plug change and start. They have that franchise. No need to be a trained mechanic. Pay the franchise fee, get the trailer and parts, go forth and replace.
#36
I went through the test sequences. Followed the trails, took the readings I could with a expanded scale digital volt meter ( HP not harbor freight), vacuum readings. Did the normal compression test, fuel pressure test.. etc. The wires were original and one meggered high so I replaced them.
I even pulled the valve cover and indicated the "cam = lifters = rocker arms" as the car's manufacturer has had a "few" issues with soft cams.
Reading the plugs is not showing an over / under rich condition. I don't have an Air/ fuel meter.
The temperature dropped here so it's still at the shop.
It's an OB1 computer so it's limited.
Last winter I had the same issue with the 10 year old snow blower, I inherited it from my neighbor who moved south. ( most years we don't need one. ) It would only run with 1/2 choke. Plugs showed lean - easy fix - gas now has 15% al in it. Drilled the carb jet 10% larger - runs great now.
#37
St. Jude Donor '05
dont see why a 434 couldnt live on the street just keep itcool. Anyone not happy wiht their brand new 427 or 434 bottom end trade you for a mint 383
#38
Why? You limited the thing. Scanner can read O2 sensor. You can read O2 sensor if you wish. Don't blame OBD1 for you not SOLDERING a wire to the O2 sensor and getting readout or using a scanner. Sure, it's not as sophisticated as the OBD2 ECM but you need to have understanding of what is going on to see what is happening.
#39
How far do the pistons come out at the bottom of the bores on a 4" stroke? I know that's a big problem with ls engines for long term oil control. A 5.3 with a 4" stroke runs great for a short time. Piston rock =wear? Wondering because I have been thinking 427.
#40
How do you read plugs on a fuel injected car since the pulse width is constantly changing? I know before I ditched all my carb toys, you put a fresh set of plugs in the Jetski, started it, do a WOT run, shut down immediately and pull the plugs and read. When you drive, the pulse width is constantly changed. WOT goes off the ECM and cruise goes off sensors so it is going to be difficult at best and a SWAG at worst.
To read the plugs = pull the plug, go inside to the shop, put it under the microscope and check the center electrode and porcelain casing. it can show the signs of a dripping injector or a clogged injector. That is how I found the injector trouble on my 85 before I scrapped the TPI. 3 injectors were leaking and one was clogged.
I went on the Ford forum, the motor in that car has a history of the damper shifting ... due to poor fit and material in the crank.. I will know when I visit the shop and look at the car on the lift. They still hove no answer - even with their Ford expert - former ford mechanic.
