87 no crank condition
Old 08-30-2015, 01:43 PM
Geardo
Geardo's Avatar
Default 87 no crank condition
It had been about a week since I last started it, went to move it, it won't crank. Tried my battery jump box, no Crank. Remove battery and installed another, no crank. I get the dash lite up, headlights will come on, stereo on, windows roll up and down, no heater, or a/c, no crank. have over 12 volts to the starter. When i turn the key to start, the security light flashs, tried 2 differnt keys, same thing.
Old 08-30-2015, 05:26 PM
Geardo
Geardo's Avatar
It must be a VATS problem
Old 08-30-2015, 10:10 PM
Cliff Harris
Cliff Harris's Avatar
Pull the error codes from the ECM. VATS error code is 46. If you don't have that one then the problem is not VATS related.
The security light has nothing to do with starting. It flashes if the door is open and the theft deterrent system is not armed.
Old 08-30-2015, 10:16 PM
jv9999
jv9999's Avatar
You can try jumping the two heavy wire on starter inhibit relay behind the info panel. Either the relay is bad, or the VATS is not turning it on. The one in my '87 went bad and drove me crazy with intermittent no crank issues.
Old 09-05-2015, 10:50 AM
Geardo
Geardo's Avatar
I jumped the relay, still no crank, I checked codes, have none.
Old 09-05-2015, 01:33 PM
s carter
s carter's Avatar
if you have good connection (both sides Positive & Neg.) to the starter from the battery, and when the key is turned the crank wire gets power, low tech test for a bad starter/relay With key turned SMACK STARTER WITH A HAMMER if it starts problem found.
Old 09-05-2015, 01:46 PM
Geardo
Geardo's Avatar
Yep, that's what I did next, and it started, but won't start without the relay bypassed. Did I have 2 problems? These old cars are fun aren't they?
gradywhite931127 (10-08-2022)
To 87 no crank condition
Quick Reply: 87 no crank condition
