Best plugs/wires?
Best plugs/wires?
I currently have AC Delco plugs and wires, put in about 2 yrs ago w/about 10-15k miles on them. Are these the recommended setup for performance? Is there any need for me to change them out to something else?
Cruise-In II Veteran
Re: Best plugs/wires? (dbwade36)
For performance plugs I run AC Delco with cut back ground electrodes (method on my site). This enhances burn efficiency to increase gas mileage and provide about 8-10hp gain.
Performance wires are spiral wound. MSD 8.5mm SuperConductors are among the lowest resistance performance wires, though I run 8.0mm TPIS wires with a higher resistance for a stock look. Some guys like Taylor or ACCEL performance wires.
An upgraded dist., like the HyperTech coil/cap/rotor provides much higher spark voltage which allows you to gap your plugs to .045"-.050" for improved burn efficiency.
Received 1,422 Likes
Re: Best plugs/wires? (Pop Chevy)
I use AC Delco plugs and MSD 8.5mm wires
I have Splitfire wires on my car and they seem to very durable. I also have Bosch Plus 4's and they too are holding up well. Unless you're in need to replace the plugs and wires in your car, I would just leave them be.
