Is this the Opti? '94
After a particularly hard drive on a nice straight road I noticed I had lost a cylinder,I am hoping it is just a plug or wire and not the Opti starting to crap out, its a 94 and does have 71K on it so Im sure some will say its due to go but its fine on the other cylinders, (its on the lefthand bank) no smoke of any colour, it wasnt missing at all up to this point either,so far as I know the plugs and wires could be originals! certainly haven't been changed in the three years I've had the car, any ideas?
If you have for sure narrowed it down to one cylinder not firing, then it is probably just a plug or wire issue. It could be the terminal for that cylinder within the Opti cap but kind of doubtful. You need to narrow it down to which cylinder exactly and then replace that plug and wire.
On my 94 I had to loosen the power steering pump and move it forward to get the wires through make sure you use a bit of dielectric gease on them and make sure they click twice. I had one cylinder stop fireing pulled the plastic cover off and found a injector wire nibbled through. Don't forget the antisize on the plugs.
I think you need a nickname how about "Always Click Twice"
