L98 Camaro Vs. L98 Corvette
Old 08-20-2002, 01:17 PM
Kdrhpe
Kdrhpe's Avatar
Default L98 Camaro Vs. L98 Corvette
Were there any differences between these two engines? I know the LT1 had several variations.
Old 08-20-2002, 01:22 PM
vader86
vader86's Avatar
Received 1,400 Likes on 1,016 Posts
Default Re: L98 Camaro Vs. L98 Corvette (Kdrhpe)
Iron head on L98 camaros
Old 08-20-2002, 01:38 PM
Huckzilla
Huckzilla's Avatar
I could be mistaken (as I often am), but I thought the cam was slightly different in both cars and the corvette had a freer-flowing exhaust.
Old 08-20-2002, 02:01 PM
TIMSPEED
TIMSPEED's Avatar
Default Re: L98 Camaro Vs. L98 Corvette (fast90)
Yeah..basically just the iron heads. The exhaust is easier to make sound better :D
Old 08-20-2002, 02:04 PM
scorp508
scorp508's Avatar
Certain years had 9.5:1 pistons I am finding out. The iron heads were also a 64cc chamber vs. our 58cc.
Old 08-20-2002, 02:10 PM
Kdrhpe
Kdrhpe's Avatar
What is the disadvantage of iron heads?
Old 08-20-2002, 02:12 PM
scorp508
scorp508's Avatar
Much heavier, worse heat dissipation, flow worse, harder to work on.
Old 08-20-2002, 02:15 PM
MrNuke
MrNuke's Avatar
Default Re: (scorp508)
I also read some L98's in f-bodies had something called
a peanut cam in them...Dunno stats, but heard those blew chunks..
Old 08-20-2002, 02:16 PM
vader86
vader86's Avatar
Mostly weight differences.
The production Iron weighs what, 45lbs? And the Dport head weighs like 20lbs, most aluminum heads are in that weight range too.
Aluminum has heat retention differences too.
Old 08-20-2002, 02:33 PM
TIMSPEED
TIMSPEED's Avatar
Default Re: L98 Camaro Vs. L98 Corvette (vader86)
My friend has an 88 IROC-Z, it's basically the same car as mine, except he has iron heads. But then again, his is easier to make faster (ie: cheaper parts, more smog-legal parts) So..I mean, it's a toss up. With about $1200 in mods, his car can run circles around mine.
Old 08-20-2002, 02:34 PM
scorp508
scorp508's Avatar
Its also a heavy sled that don't handle the same. :)
p.s.
Mine is for sale. :D
[Modified by scorp508, 1:34 PM 8/20/2002]
Old 08-20-2002, 03:11 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
The F-body L98 (in production in '87) had iron heads, larger chambers (and so different pistons too), log manifolds and internal EGR but I believe it had a roller cam as did our L98.
One of the F-body mods of that era was to upgrade to "Vette heads".
BTW, the "peanut cam" was an '86 special from the General, used in the LB9 motor.
As mentioned, the F-body (at least the '86 IROC) was heavier than the contemporary Vette; my IROC launches at 3,780lbs and the Vette at 3,350lbs.
To L98 Camaro Vs. L98 Corvette
Quick Reply: L98 Camaro Vs. L98 Corvette
