DOOR BOSE AMP REMOVAL
I have a 88 with a BOSE stereo. Without resorting to using a saber saw or pulling the window out, how to you get the AMP out of the housing in the door panels?
Re: DOOR BOSE AMP REMOVAL (HAD2HAV2)
I don't think there's a way to actually get the amp out of the door, without cutting at least a LITTLE BIT. What are you trying to do? :cheers:
Re: DOOR BOSE AMP REMOVAL (TIMSPEED)
I broke off pieces of mine with a set of channell locks until it fit throught the hole. It was a really PITA and took some time.
I have an 89 convertible and had to remove both sides. With the panel off, and the inside door handle, release the linkages to the lock from the white plastic retainers, including the one to the pwr door lock solonoid. be very careful not to break the plastic!!! I don't know where to get replacements. I took the water seperator (platic sheet) and carefully removed it from the plastic rivets and adhesive on the bottom so that it could be reused. Anyway, once all of that is done, with the window up, you can take out the screws securing the accessory plate (silver colored panel inside the door). You can the shift the plate around to the rear of the door and gain room to get the speaker enclosure out through a gap at the bottom front of the door. Probably helpful would be to release the wiring harness from the plate to facilitate access. Be careful in removing the speaker in that it is secured with adhesivein addition to the four screws. Someone told me that if you push on the tabs to break loose the adhesive, that the tabs holding the nuts would break off and I belive it. That is, assuming you will repair and re-install the enclosures. After repairing all 4 speakers, I have pretty decent sound. It is not up to year 2002 standards, but it surprised me - it is not bad up to about 50 or 60 MPH. After that there is not enough power to overcome the wind noise of a convertible. Hope this helps.
You must remove the bose case from the door, I did this in my 89 and did not cut or break anything. It will look like there is no way it will fit thru the hole, but with some mild persuasion, it will come out and go back in. Once you get the housing ut it is pretty straight forward.
drive it, as it was meant to be driven!!!!
If you intend to reinstall dont use the dremel, you dont need it and you will have a problem reinstalling it. I am not super mechanical and got the job done. Got both sides done with only one six pack.
