Under hood lights...any easy way to turn them off?
St. Jude Donor '06-'07-'08-'09-'10
Under hood lights...any easy way to turn them off with the hood open?
I'd prefer to keep my hood open at shows, drags, etc. but, i don't want to run down the battery. And i really don't want to disconnect the battery cable. I was thinking about splicing in a simple toggle switch to the lights. Any thoughts or suggestions? :cheers:
1 Post
Re: Under hood lights...any easy way to turn them off? (Hardcorvette)
If you follow the wires down the hood, you'll find the electrical connector. Just disconnect it!!! :yesnod:
:cheers:
:cheers:
Down in the front drivers-side "well" near the nose is a fuse clipped into a little covering. You can remove the fuse and this will turn off the lights. I think that this is documented in the owners manual but I'm not positive.
[Modified by TravisD, 4:00 PM 8/19/2002]
Re: Under hood lights...any easy way to turn them off? (FoolCrzy)
:cheers:
:cheers:
That is exactly what I did with my 88. Works great.
Cruise-In II Veteran
Those are the inexpensive ways.
I got the kit from MAD that comes with a wiring harness within spiral wrap and a switch box. The box is stuck to the front of my left inner fender well so that it can't be easily seen. The package looks neat and the flick of a switch gets the job done.
Elite Torch Red Member
Re: Under hood lights...any easy way to turn them off? (Rick92)
use the fuse method, easiest way.
Re: Under hood lights...any easy way to turn them off? (rcolling)
The fuse it is! Thanks for the help. :cheers:
Location: 63.8% of all statistics are made up on the spot.
1 Post
St. Jude Donor '08-'10
:cheers:
:cheers:
Location: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
1 Post
Re: Under hood lights...any easy way to turn them off? (joecaver)
:cheers:
Very easy to find and do.
:cheers:
(sorta non related) In my sick quest for less weight, I removed both light assembies. Even better now is whenever I need light on something I can just plug in the light assy and the wires are long enough to reach the rear of the engine. All I need to do is glue a magnet to the light housing and I can stick it where I need it most.
Cruise-In I Veteran
I have found that if I raise the hood to about 2 in from full up position then the lights don't come on.
Re: Under hood lights...any easy way to turn them off? (Vette Ed)
I installed the Mid America switch also. Very easy to intall and looks professional. I leave the lamps off, cause the switch is so easy to find even in the dark.
I installed the Mid America switch also. Very easy to install and looks professional. I leave the lamps off, cause the switch is so easy to find even in the dark.
Re: Under hood lights...any easy way to turn them off? (TravisD)
