Broken vacuum line fitting
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
While trying to connect a fuel pressure gauge I snapped a vacuum line fitting by the passenger side fuel rail.
It's a 92 that has a miss and since I've retired I'm finally able to spend some time on fixing it.
The fitting has thee lines connected to it. Any know if it performs a function other than connecting the three lines? From the looks of it it may contain a valve of some sort. Can't find a diagram online that describes it or a part number.
Thanks guys. I'll do a NAPA run tomorrow, hopefully they'll have one. Strange thing is I broke the line when the car was in the driveway. It seemed to run better with the line broken than it normally has been......
As to the yellow arrow the secret is MS Paint....
Bonehead
