Replacing driver's side window regulator -- new one won't fit?
My early C4 has the original ribbon-style window regulators, and the driver's side finally broke. I ordered a replacement from Eckler's, listed as an original GM part, in the newer scissors-style.
Aside from the fact that it's not a simple drop-in replacement (you're required to drill new mounting holes for the bottom of the bracket), the new part just does not seem to fit at ALL. When the top holes are lined up, the bottom of the regulator is not anywhere close to where it needs to be. When I try to push the bottom over (towards the inner part of the door), it seems to hang up on something; either the motor is pushing against the door, or one of the lower mounting brackets is too long. The rearward bottom bracket has plenty of space to move in and out, and lines up fine with the hole I drilled. However, the front bracket won't come near the hole (it won't slide far enough towards the inner door lip), which is in line with the two original holes and the one for the rear bracket.
When I pull the regulator back out, the front bottom bracket looks like it's been rubbing against the inner door -- the edge has a new coating of red paint and fiberglass powder.
Does this sound like a defective part? Can someone who has done this replacement offer some suggestions? I did not expect this to be as difficult as it seems to be.
Thanks.
[RICHR]
Thanks.
[RICHR]
Video for installation.... my apologies, if it is useless:
More instructions: http://www.corvettemagazine.com/tech...grade-install/
More info: https://www.corvetteforum.com/forums...placement.html
It's been years since I upgraded both sides, but I did not have a single problem.
My 86, already had the holes from the factory, for the new style reg.
Is yours an early 86 ?
Years ago Central Coaster did a writeup with pics, have you seen it ?
http://webpages.charter.net/khasting...windowreg.html
Early '86, yes. Somewhere in the low 3k's by the VIN, still had cast-iron heads when I got it. Definitely no holes for the newer style...
Haven't seen that writeup; I'll give it a look, thanks.
Seabright, thanks, but that video is basically just an ad for MAM's product.
[RICHR]
[RICHR]
Thanks.
[RICHR]
had to drill 2 more I believe. Here is the way it should go
Good luck
Hi
I upgraded to the later style and had to drill a hole in the bottom of the door, there were no issues fitting the later style to my 85.
I pretty much put the top bolts in finger tight and marked where the hole had to be drilled in the bottom, removed it drilled the hole and installed the regulator all ok.
Hint.
Make sure you cable tie te wiring to the window regulator motor connector, there is no slack and the connector can be pulled on an angle making the regulator stop working.
If you have removed the guide bracket, that needs to be fitted in exactly the same spot or the window will go up too far or not enough.
There is also an upside down L bracket, near the front of the door to limit the front window height.
The guide bracket also affects the tilt of the glass, but you should not have to touch that bolt inside the door.
good luck
Hint.
good luck
It's been working great for the last four years, though TBH I don't often raise/lower the windows -- since it's garage-kept, once the targa comes off for the summer, the windows tend to stay down.
[RICHR]
