Front turn signals an front curb lights dont work but rear turn do
The front turn signal's along with the blinker indicators in the gauge cluster do not come on along with at night time at the headlights on the courtesy curb lights on the Front side of the car don't come on either four-way switch doesn't make a difference but the rear blinkers work and for Ways I know the indicator works in the dashboard because if you pull the bold out tale late in the front The indicator lights up to let you know the bulb is out
You might try that again mentioning first the year and then with the key on mention which lamps light with the left turn signal engaged, then the right. It's difficult to sort through that and try to figure out what you say the "cornering" lamps are doing.
Just rethink the entire statement.
Check your grounds
All of that with absolutely no punctuation. WOW
**** you lol ..
