Check Engine Soon
Check Engine Soon
My check engine soon light comes on every once in a while.Also I noticed it happens when a cooling fan comes on around 194.You can cut engine and re-start and the light is off.
So today I let it sit and idle until the fan went on around 228 and went off around 215 or so.The check engine didn't come on under those conditions.Check engine just comes on when fan starts prematurely.
Anything to worry about?Its a 1992
Thanks,
Tony
Thanks,
Tony
It never runs hot going down the road,around 190.
thanks,
Tony
Have you tried disconnecting the battery to clear the code(s)? See if the light will go on again.
