Will 84-87 16"wheels fit an 88 with 12"brakes?
Pro Mechanic
What "12" brakes?
The '84 caem with something like 11.7" brakes and it's 18" wheels fit fine.
They should fit fine unless you're talking about some big aftermarket "12" brake package".
Pro Mechanic
I'm thinking about putting an 88 knuckle with the dual caliper and 12"rotor on an early car to improve braking while keeping the stock 16'wheel
I'm not sure if the 88's +/- 20 mm additional offset was due to the way the knuckle was made or the length of the wishbone arms or both? anyone know?
Pro Mechanic
Both. Knuckle is different, lower arm is different.
Actually both LCA, UCA & knuckle is different. Outer tie rod length was also changed to accommodate the tread width increase. There's many upgrades for the brakes but as to whether the wheel will fit with all of them is another story.
Did the 88 cars have ABS? Did the base models with 16" wheels have 8.5 or 9.5 widths? or both with different offsets?Did the factory camber and caster settings change from the earlier cars ? track width change?
I have an 88 Verte that has the Z52 package on it and it came with 17" wheels. And yes, in 88 they do have ABS brakes. The Z52 was an option for the car as most of them had 16" tires. My tire size is 275/40x17. Hope this helps.
Tommy
Tommy
I put the J55 13" rotors on my car and the calipers scraped the inside of the Z51 wheels, which I was told wouldn't happen. 17" wheels fixed the problem.
Cliff, were your (factory) wheels made by Enkei? I remember reading that the Enkei wheels provided more clearance, not sure it this was true. I bailed and went to 17"s
Thanks Tommy and Cliff,
ABS cars usually have more offset to for a more negative scrub radius which makes the car more stable under ABS braking…
Are the J55 13" rotors the same thickness as the 12"or 11.5"?
I wish i could compare an 88 knuckle to an early to see what other difference there might be other than the caliper mounting points.
'88 16" wheels were only done in 8.5" widths, they were directional but aside from that they were identical on all four. There were no offset choices. Yes the alignment specifications changed.
