Decode LT4
Does the SPID label have Z51 on it? I guess you don't know or you wouldn't be asking but the SPID label with all of the RPO's would be in the rear storage compartment. If the SPID label is missing then take your VIN to a GM parts dept and ask that they print you an RPO list for your VIN. I'd think they would accommodate you.
This is generally considered to be a very accurate C4 RPO decoder. It's not what I use but it should be very helpful:
http://www.corvetteactioncenter.com/...o/8496rpo.html
A quick clue would be to look at the wheels and tires. The standard coupe with Z51 got 275/40-17 tires and 17x9.5" 5-spoke ZR-1 style wheels on all 4 corners. Of course it's possible that a previous owner may have upgraded the tires and wheels.
I don't believe that Z51 got 5-spokes except on the appropriate cars, GS and CE specifically.
I don't believe that Z51 got 5 spokes except on the appropriate cars. Z51 on a non-GS or CE car I believe would have saw-blades. Check the tire placard and the tire sizes maybe as well as the SPID label.
Checked the tires and the RPO codes. Both confirm it's not the Z51 package. Guess what I need to do now is create a future plan to upgrade the suspension. I wonder if CoilOvers would suffice? I plan to do some autocross events throughout the next Summer.
