c4 aerodynamics for less drag
So I'm tweaking my street driven -96 for standing mile events and I would like to know what there is to do for less drag.
I already have rear diffuser that smooths out the area after rear diff, but can anyone come up with something else?
Thanks guys!
Thanks guys!
Pro Mechanic
And make an air dam that does to the ground across the front, and down both the rockers.
Take off the side view mirrors.
Block airflow through the radiator (to the extent that it can maintain temps through the run)
Disk wheel covers.
#1 drag is frontal area. The more perpendicular to direction of air the worse the drag. (not much you can do about this w/o body work).
#2 is air flowing through engine room, under car, tire wells, and behind rear. This is dirty (turbulent) air flow that adds drag / consumes power. Small things that help are taping off frontal openings and removing the seal between hood and firewall. (lets the high pressure in the cowl area bleed down the firewall and helps sweep away heat off the exhaust)
Best way to help both of those is to lower the car as much as is possible.
Next best thing is to get the engine into the TQ peak as quickly as possible in top gear.
Everything else is just a matter of increasing efficiency of something that is already helping or hurting you.
- Brakes dragging? (do a quick left / right bobble of the steering wheel after you launch to help the front pads move away from the disk)
- Remove mirrors
- Make a true ram air system to help pack the intake w/cool air. In place of the front license plate is a great way to kill two birds with one stone
- Take about 3/4 of a quart of oil out of the engine (from the full mark)
- Install a alternator cut out switch
- Make sure the cabin body vent is operating
- Remove mirrors
- Remove mirrors
- Remove mirrors
Tommy
Received 3,043 Likes
St. Jude Donor '05
Narrower tires make sure air pressure hot is optimal
Cruise-In II Veteran
I agree with lowering the car to get the tires out of the air stream and inflating the tires to reduce rolling resistance.
Lose the spare & jack and arrive with 1/4 tank of fuel to reduce weight and aid acceleration.
Just know that the C4 Corvette was one of the most aerodynamic cars built in it's day in it's stock form so your way ahead of the game to start with. Below are the numbers for Coefficient of drag......WW
Coefficient of drag by years:
'73 .325 (X-882 Mid-Engine 4-Rotor Wankle Corvette)
'80 .443
'84 .34
'86-'90 .33
'91 .29
'96 .31
'97 .29
'98 .29/.32 (Conv't)
'99-'03 .29/.32/.31 (Fixed Roof Coupe)
'80 .443
'84 .34
'86-'90 .33
'91 .29
'96 .31
'97 .29
great to see a member doing the standing mile events. I'd like to get involved but first I have to get my car running good. How much power do you make and how fast do you want to go?
Last year I did 163mph. My current goal is to make 168mph without touching the engine.
