ok I have a weird one and need help
okay so when my headlights are on my right turn signal indicator on the dash stays on. when I click the flasher on it flashes. when its off it stays solid. how do I fix it?
Spray some contact cleaner into the bulb socket to clean it up. Check the headlight grounds as well. Typically when you have a solid indicator on the dash the bulb is burnt out or you have bad contact somewhere. Grounds are the most likely culprit followed by a bad socket if the bulb is ok.
Good luck!
Good luck!
you have a a grounding problem from one of yuor park lights. The best way to find out what one would be to pull the bulbs one at a tim till it goes out, Sense you say R/F is weak that is where I would start
