1994 A/C Pressure Switch Leak
Old 08-01-2014, 05:59 PM
TorchTarga94
TorchTarga94's Avatar
Default 1994 A/C Pressure Switch Leak
Has anyone had a leak from the A/C Pressure Switch? The switch I am talking about is in this thread:
http://forums.corvetteforum.com/c4-t...or-93-lt1.html
I was working under the hood today and the electrical connector that attaches to this switch is coated in a light green oil, it almost looks like coolant but it appears to be refrigerant oil. Has anyone replaced this switch with success? If I remove the switch will all the refrigerant be released or is there a shrader valve that allows you to attach and remove the switch? I noticed a green O-ring was loose and was on the body of the connector, it seems like it would seal something but I am not sure.
Any help is appreciated,
Patrick
Old 08-01-2014, 06:20 PM
TorchTarga94
Just wanted to give a quick reply. After scouring the FSM it appears the switch is on a shrader valve and can be replaced. Found a replacement switch part #36659 for $10. Will report back if the leak stops.
Old 08-01-2014, 10:23 PM
TorchTarga94
Problem solved. Thanks Torch!
Ahhh your bloody crikey welcome mate!!
Cheers mate good day.
Old 08-02-2014, 04:04 AM
65Z01
65Z01's Avatar
Cruise-In II Veteran
Congrats on the easy fix and thanks for posting the solution, ya never know when it will come in handy...
To 1994 A/C Pressure Switch Leak
Quick Reply: 1994 A/C Pressure Switch Leak
