Data master files
Data master files
Anyone have any experience with Data Master files and using them to determine problems?
I have a 92 LT1 stroked to a 383 with a hot cam and I am having problems with my IAC valve not working correctly and my data log shows it. Seems like the ECM will not control my idle and I have a miss or surging at just off of idle cruising. If anyone can look at my file and give me an idea of what might be causing my problems it would be very appreciated.
I changed the .uni extension to .txt to attach it to this post if anyone can look over the file and give me some feedback on what I might start with on trouble shooting this I would really appreciate it , like I just said before.
Thanks a lot ahead of time.
Also my engine dies when I floor it and hit 81 miles an hour in third gear. It's like it just runs out of gas but I ran it with the fuel gauge attached and fuel is still at 43 when it dies. It will start right back up if I let my foot off the gas immediately after it stalls but if I hold the peddle down it won't restart and the tranny will disengage and I have to use the key to start it back up. Some weird **** I have never seen before. There is no way to test if I am loosing spark but what would cause the spark if I am loosing it to start again as soon as the throttle is moved? And not come back if I keep the throttle floored?
thanks again guys.
thanks again guys.
thanks again guys.
thanks again guys.
PLEASE At least one post would be helpful, I don't want to replace my Opti if the problem lies in my CCM!
Anyone out there that can address this issue or has heard of it before please reply!
Thank you
Daved2
I had a code 41 on the ECM the other day and that code is serial data link failure and it says when that code is set it will prohibit the feds from engaging and doesn't say what parts to change it just has a bunch of continuity test to do between connectors one the ECM and CCM and I am not tearing my whole dash apart to get to the CCM to do those tests.
Weird stuff huh?
I was just about to buy another Opti spark and decided to do this test, glad I did saved myself a bunch of money.
I guess there is some limit set in the ccm that I hit at 81 MPH but when it don't know I'm doing 81 it doesn't stall the car or shut off the FEDS.
Thanks for the reply though very appreciated!
My file
Daved2
The time where the stall took place is at three points and the TPS reading is in the area of 93.5 and 94 on that % at 81 miles an hour the stall takes place and then the timing goes to 3 degrees advance, when you see that portion you are in the right place on the file. It happened three times on that file and you will see the injectors drop off as well.
I have an Trans am with lt1 It runs bad first ok than goes wild on idle
Can anyone read my uni file I converted to txt file and maybe telling me what is going on with this thing driving me crazy thanks everyone.
