Corvette newbie 88 dream car
Just wondering the speedometer is the only thing that is bright enough to be see at night how do I fix this ????? Also paint is bubbled up and chipped on hood and right below mirrors don't have a lot of money yet wondering if it is ok to do a quick fix with the good old spray can just till I can paint car right just wanna know I can use regular primer and paint for a temp fix
Dash bulbs
If your dash is like mine, you may not have to remove and disassemble the instrument cluster to change out the bulbs. After removing the bezel over the instrument cluster (be careful so you don't drop any screws between the steering column and dash - they're a bear to get out if you do) there are 4 metal plugs on the front of the cluster. I just hooked a finger nail under the edge and they popped out. Now for the bulbs (there are 2 types and you need the correct ones to match what you currently have), I wrapped some tape with the sticky side out on a pair of hemostat jaws and carefully grabbed the bulbs through the front and pulled them out. The difference in the bulbs are the pins, one type has straight pins (called bi-pin) while the other has the contacts bent around the end of the bulb, take it slow and easy and push the new bulb into the socket and put the plug back on the hole where the bulb goes. Do all 4 of the bulbs that way.
It was last year I did mine which are the bi-pin straight leg bulbs, IIRC I got them at either Eckler's or Corvette Central. They are not carried at my local dealer or auto parts stores. You need to use the type bulbs that's currently in the dash because the socket appears to be different between the 2. If you take the dash out and disassemble it to change the bulbs, you can use either as long as you have the matching sockets for the bulbs you get.
Hope that helps.
Hope that helps.
