air conditioning pressure range
looks like im going to have to look deaper into the problem. As soon as i got up over 40 psi it quit kicking in and out and stayed running and I have cold air now. Pressure shows 43lbs on my guage. Its a cheap china guage though so maybe its just junk. When left idle overnight what should the pressure equalize out to? Churchkey im not doubting your expertise. Opinions like your qualified one is what im looking for here and i thank you.
1. Remove the connector from the low pressure cycling switch
2. Install a jumper in the connector to simulate a closed switch
3. Run the A/C and see if it still shuts off at 40 psi
If it shuts off you have a problem elsewhere. If it continues to run, the switch is suspect.
