Tank Vapor Canister
Tank Vapor Canister
I had excessive pressure building up in my tank so I decided to investigate. Through the power of search I found that a clogged vapor canister or line would cause this. I took the lines apart at the fittings and tried blowing air through both. No luck on the canister so I have a new one on order. I tried blowing out the line and I did get a lot of little rubber bb's to come out but there is a clog in the hard plastic line that runs up to the purge valve that I can not get out.
Can I replace the hard plastic line with a rubber line?
Sorry for the long story.
