where do I buy a CCM for a 93' vette
I have all but determined that I need to replace my CCM. Does anyone know where to purchase a new or rebuilt one? 1993 corvette coupe base model. Thanks
Davies does ECM/CCM but I doubt it's "in-house". You would need to ask them.
http://corvetteparts.com/catalog?q=ccm
http://parts.nalleygmc.com/products/.../88999216.html
Appears it's still available from GM. There is a core charge and you need someone with a Tech 1 to program the new/re-manufactured one.
CCM's... this is fun... they are easy to find, rather cheap and, well, insanely durable, so why is yours bad?
A new one is the way to go, but you need to get it programmed with the mileage within the first 100 miles, or else it will lock up and never be changed, ever, by anyone. I have never heard of anyone hacking that data.
If you buy used, well, it's 20 years old and might experience the same issue you are now.
Before you replace it, make sure all grounds are good and solid... like any piece of electronics, grounding is SO very important.
Pro Mechanic
Based on conversations with this person, he can rebuild, reprogram...do what ever you want. His name is Ken Anderson. I'd recommend at least talking with him.
kenwanderson@msn.com
FYI, I agree that it's very uncommon for a CCM to fail. I thought mine had failed which is why I was talking with Ken, but further....unconventional diagnosis proved it was good and my problem was the wrong key supplied by the PO of the car.
