Fuel pressure tester needle flutters violently?
You've been give a couple of suggestions. 1. Did you install the washer under the fuel pressure regulator cap? When you turn the screw to adjust pressure, the screw should be pressing on the washer. 2. The fuel pump pulses. There is a pulsator located in the fuel line coming off the stock pump. When you install the new 255 lph pump (and I know you will), throw away the pulsator and install a piece of 3/8 fuel line in its place.
In any case, the flutter is not causing operability problems. When adjusting the fuel pressure just adjust for the middle of the needle swings.
You have some kind of contamination issue then. Looks like gas on top of water....I have 8 different vehicles that I start up sometimes every couple of years, no issues. You need to fix that.
What I dont get is how did you `drain` this sample. If you drained it from underneath you would think it would be all water. If you drew it out with a hose and the hose was pushed to near the bottom you would think it would be all water.
Unless its a thin layer at the bottom? It couldve been in there before?
I think believing that it being an ethanol blend means its likely to seperate or something in 2 months is pure baloney. I had a car sit for over a year with 10% ethanol and never had a problem.
Your gas should be clear and void of any contaminates. One way that you can get contaminated gas from a gas station is when bulk trucks deliver the product to the station. The fill hoses are under pressure from the tanker and the stations fuel tanks are at their lowest points which will allow contaminates to float around. If you ever see a tanker filling the stations tanks, DO NOT get gas that day. I can tell you this from experience! In fact this is not only true in Az but this occurs all over the U.S. Watch before you fuel up!
Tommy
Pro Mechanic
So does your fuel pressure fall off under WOT?
your fuel is containanted. Fuel does not go bad in 2 months most fuel is good for at least 2 yrs esp with a larger quantiy in the tank. Like others have said you need to check the seal by your filler and make suure the drain is clear. i would drain all the fuel out dump a couple cans of dry gas in there add 5 gal, fuel run it low fill it back up. If you get the fuel from the same place I would ask them when the last time their fuel was tested. One thing I make sure of is to always get fuel where they go thru a lot of fuel.
The pump output pulsates. If the fuel pressure regulator is not working then the pressure will pulsate also. If you dial down the pressure the fluctuations will go away. At 60 PSI the regulator is not working.
#33
I high pressure and volume pump can cause the pressure gauge to pulsate quickly when there is very little fuel use at idle. When you installed the high flow pump did you remove the factory pulsator that is in the fuel pump? Go drive the car with the fuel pressure gauge hooked up and put it under some load, the pulsing should go away and then you can check your pressure. Mine pulsates at idle and it works fine as soon as it is under load.
#35
FYI, There is no issue with 60 PSI, you just need to tune for it. The factory LS1's all use 60 PSI and those injectors can also be run at 43 PSI. You just need to adjust the flow rate in the tune to compensate for the pressure change.
#36
I was wondering if the FPR was maxed out at 60 psi. Wouldn't that would make the spring all the way "tight"? Of course, we will never know what the fix was or anything else. I told myself I was not going to comment anymore on this car, but I had the same problem at one time and thought I could help. This will end up another 300+ comment thread with no answers lol. My bad.
#37
I think he was trying to test his stock pump at WOT to see if he needed a high volume pump. I would say "yes" with his mods, if he ever gets it running right, or it actually is, which nobody knows and is a whole 'nother epic thread.
#38
Pro Mechanic
#39
Tommy
#40
My fuel pressure tester isn't long enough to reach my windshield, but the fuel pressure dropped off simply when I revved the engine.
