Proportioning spring
To preface this: I have a 63 Grand Sport with c6 front brakes, c4 rears, and 96 c4 master cylinder.
I installed the DRM spring and it helped add rear bias, however, I still need to add more rear. I purchased an 02 camaro master and was planning to install a proportioning valve in line of the rear however the master is too large to fit in the fender where my booster is mounted.
My question is: What would happen if I removed the spring completely and installed the proportioning valve in line of the rear with the c4 master?
I believe that master requires something in that position. I would certainly think so!
Thanks for the response. Yeah after comparing the stock and DRM spring I believe the DRM spring is stiffer. Taking the spring out may actually make the problem worse. But there is def an off the shelf solution.
I ended up finding a C5 Master cylinder laying around in the shop. The reservoir on the c5 unit is smaller than the camaro unit and ended up fitting up in the fender. I took the C5 reservoir and put it on the camaro unit since I already had all the adapter fittings for the camaro master. Stayed up til 3am! But it's in there!
If you had or acquired all of the comparison dimensions and resistance using a site similar to this could maybe accomplish what I mentioned.
I've never purchased from these people but I'm somewhat familiar with their procedures in their questionnaire for sourcing from them.
http://www.acxesspring.com/spring-constant-units.html
