Dilemma?
Dilemma?
OK, I purchased my 1989 c4 less than a month ago, today I took it to a friend to discuss several issues. (I have to go back to get them looked at) He is a engine builder for Racing Teams (certified) yes those teams, he offered to boost my car to 600+ hp I am thinking it over... this car was supposed to be a weekend cruiser not a weekend bruiser. Now i do agree that some tuning is needed as take off id great but after that it lacks some power... What should I do? Help!
Set the fuel pressure to 48-52 psi and enjoy the ride.
That will knock a second of your quarter mile time and start easy and be well behaved in heavy traffic.
If you want more hp a TPIS cam for TPI engines works a treat, some aftermarket heads will put you into 12 sec quarters.
It's easy to get caught up in the 600hp small block game. Kinda like a high maintenance woman, they are intriguing to get, but hard to live with. I actually just sold a 540hp small block 400 to put in a nice 350 with a LT4 cam and heads, and headers and upgraded intake.
I can get decent performance and good gas mileage, and not wrestle with brakes, and actually enjoy driving the car with a/c.
Of course I'm getting older now and appreciate the refined aspects of a car.
Good luck
Good luck
I am 50 and all the things that you have mentioned is what I have on my mind. Good advice. We'll I am seeing him on Monday or Tuesday and we will work this out. I have to remember my wife also drives this car.
Cruise-In II Veteran
Years ago TPIS did a build up on a 90 or 91 Vette with exhaust, intake, cam and heads to get around 350-370chp and commented that this is the Vette that GM should have built. I would also suggest ignition improvement like a HyperTech coil/cap/rotor and low resistance wires.
If it has an A4 I would also suggest a 2,000rpm TC with TransGo shift kit. And have the WOT shift points raised to 5,800-6,000rpm. But keep the 2.59 rear for cruzin comfort.
Actually, having to do it over again, I probably would start with the Lt1 platform. They have decent all around performance, except for the opti-spark. It's going to take a lot of work and money to make an L98 a quick car, and a few of grand at least.
Lots of similar questions if you search.
Here's a rundown:
Phase 1
Corsa Exhaust $1100
TPIS or Hedmen Headers $400 - 800
High Flow Intake $400
High Flow runners $300
Tune $200-500
Phase 2
Stall converter $350-600
3:73 Gears $400-1500
Heads $750 - 1500
Cam $150 - 350
Super - Ram / Mini-ram intake $1000 - 1500
Re-tune the car
If you think a carb conversion will be cheaper been there done that. The exhaust will stink, the a/c wont work right, and the car will never behave like it was meant to. This all varies like opinions, of course. If you want the car to work like a 68 Nova, I would buy one of those.
But if you like the car, thats the deal. The prices I mentioned vary greatly depending on who does the work, and every change will affect the behavior, driveability, & fuel economy.
Choose wisely grasshopper......
Here's a rundown:
Phase 1
Corsa Exhaust $1100
Tune $200-500
Phase 2
Heads $750 - 1500
Cam $150 - 350
Re-tune the car
Thanks for the good advice... Exhaust done, headers done, cam done all by previous owner. I think they also changed heads as the spark plugs are from a different year.(I think LT1)
Done...
I also found out that the timing was off by 6 degrees, throttle body was leaking air and the EGR, MAF, and a couple other things were blocked or coated with carbon. My drivers side rear caliper was sticking and one side of the exhaust was loose. Whew!
Now I can say that I have a Corvette. And it feels like it should in the seat of your pants.
