Why a high volume oil pump causes problems..
Why a high volume oil pump causes problems..with Pictures
I have read on many forums about the use of a high volume oil pump causing problems with premature wear on both distributor gears and cam gears. It seems the added pressure from the HV oil pump pushing oil through the motor and building back pressure causes the pump to put more stress on the gears..This is why I fully expected my distributor gear to be well worn when checking it today since I now have 25,000 miles on my motor built by Pete Kane a few years ago..To my surprise the distributor gear looks brand new with no wear at all, just a few bright spots where the 2 gears engauge...After talking to a local engine builder I found out why Im not having the problems that many experience using a high volume pump...When Pete Kane built my motor he went out of his way to make sure the oil flow in my block was sufficient so as not to cause back pressure from the HV oil pump..He opened up areas where the oil would flow, and where it would return..By doing this he eliminated the back pressure most experience with a high volume pump, and also increased the amount of oil flowing through the block for a more efficent oiling system...Most that have the problem with cam and distributor gears wearing prematurly with a HV pump, use the method of putting a .030 X.030 inch slit in the bottom lobe on the distributor housing, allowing oil to drip or spray on the 2 gears, instead of relying on the splash method of gear oiling SB chevy engines use.. If your having an engine built, it would be in your best interest to have the mods below performed by the machinest in order for you to run a HV oil pump, the HV pump will get more oil flowing through the motor doing a better job of lubricating the entire engine..With the mods below and a HV oil pump, my cold start oil pressure is 62 psi, and my hot running oil pressure is around 50 psi on the highway. These are pretty normal pressures for a newer engine, but the difference is , I have much more oil going through my engine, being delivered where needed with the high volume pump , and that's a good thing...
Here are the pictures Pete shot of the areas he modified for better oil flow...
This is stock depth
This is after enlarging the oil channel allowing for much better flow to the bearings..
Hole enlarged for better flow from oil pump
Enlarged for better return flow..
He then further inlarged and smoothed the area for better return flow
Enlarging and deburring with dremel tool.
This is stock depth
..... High volume oil pumps work well with low viscosity motor oils and oil coolers ... other than that they are generally not needed in small block Chevy engines ......
But I like the extra attention to detail paid by your builder. Looks nice, great stuff
Yup, an engine's internal parts only need enough oil flow to be lubricated and cooled. More oil flow does not mean better lubrication or less wear, it means slightly better oil cooling of the internal parts and slightly better flow through an oil cooler. And more flow through a cooler is not necessarily good since the oil needs to spend some time in there to be effectively cooled.
Received 3,043 Likes
St. Jude Donor '05
I used one in mine only because it can turn some rpm and helps cool the springs a touch or id like to think anyway
Have gotten a little wear probably due to the billet cam gear that found its way on there that wasnt supposed to be
I dont run more than 10/30 syn and wait til the oil (not just coolant) is good and hotbefore I stand on it.
x2 on a stock pump doing the job 90% of the time
Change to a Z/28 spring if higher pressure makes you feel better
SBC have a very good oiling system
I have a high volume oil pump in my 383, have never seen a drop in oil pressure at high rpm or acceleration. I guess the oil must be finding its way back to the sump then.
My previous car had a high volume oil pump,the 351 ford cleveland engine i had that loved spinning to 8,500 rpm but that did have a larger sump.
A small block has a good oiling system stock. Unless you are running a loose engine, with big bearing and rod side clearances a stock pump is fine.
Small blocks do like to oil heavy on the top end, adding oil restictors in the galley plugs will keep the oil in the pan, where it belongs at the oil pump pickup.
Adding a windage tray for high RPM engines is a good idea. It offers a small HP improvement, but keeps the oil from being "Foamed" from the crank throws causing turbulence in the oil pan.
10 psi for every 1000 rpms is good. You don't need 60 or 80 psi hot oil pressure unless you are turning major rpms. Oil starvation usually causes engine failures, not lack of pressure.
Any small block Ive ever built, I always chamfered the oil drain back holes in the top end of the block. Also, on the heads (iron old skool) I cleaned the edges of all the drain back bores. Its a good practice for any engine IMHO.
Sounds like you had one heck of a good mechanic to do all of that on his own instead of letting you learn the hard way. He should be commended and you should feel lucky to have that kind of machinist!!
Tommy
Tommy
http://speedtalk.com/forum/viewtopic.php?f=1&t=6176
Here is an interesting thread on another site that talks about the effects of high volume pumps. Some pretty good information - - both pro and con.
Like any group of scientists, there is not a universal consensus
Enjoy -
Jake -
Enjoy -
Jake -
I was searching past info on oil pressure and noted back in May 2008, WW stated:
and was curious to see that WW did a ZZ4 short block replacement a couple years back, what prompted the replacement engine and do you (WW) still stand by your original statement about oil pressure above, or do you consider it too low now?
I have about 18 psi hot idle and 35 cruising with a max of 39 after a ZZ4 short block swap ('89 coup auto ) using standard oil pump.
, my 89 has a hot idle of 10-psi and its been like that since I have owned it , no problems, the L98 warning light on the oil pressure doesn't come on until it gets down to 4-psi. When running down the road at 55mph -1400 rpms I have around 30psi or so, again, no problems. Coolant temp on a 70 degree day running at 40 or 50mph is between 190 and 195 degrees. WW
Quote.... my 89 has a hot idle of 10-psi and its been like that since I have owned it , no problems, the L98 warning light on the oil pressure doesn't come on until it gets down to 4-psi. When running down the road at 55mph -1400 rpms I have around 30psi or so, again, no problems. Coolant temp on a 70 degree day running at 40 or 50mph is between 190 and 195 degrees. WW ...Unquote
Below is the plug Im refering to , if it's not installed your oil pressures can be half of what they should be, and it's not unheard of for builders to forget this plug......
This is stock depth
This is stock depth
As a matter of fact a friend of mine is now running that engine in his pickup truck with no problems, and it still has the same oil pressure....
I got the ZZ4 from GM directly ($2300) and installed it myself. That's interesting that's there a plug under the oil pump. Who'd thunk to double check this before installing. Something to keep in mind though if I ever have to go under there. I'll check my old engine when for reference.
I've got a mechanical gauge and plan to test things out after break in. I did replace the oil sender a few months ago (before the engine swap) and the new sender actually read about 5 psi lower.
It's strange that my old engine had about the same oil pressure at cold start up as the new ZZ4 - 39 psi - I never remember ever seeing more than that.
