Ok guys........... My fuel pump works...... Idk how well but it works. I have not taken a fuel pressure reading because I don't have a guage ATM. The car as of right now is running pretty well ie. multiple runs at WOT to redline with minimal sputtering
Ok so I pretty much have 0 fuel pressure with the ignition on and the car off. With the car on it sprays a tiny bit. I do not have a fuel pressure guage, but will have one tomorrow
How did you get a 0 reading with no gauge? Did you change the filter by chance?
Rent a FP gauge from the auto parts store. Before you do that, check your fuel pressure regulator, easy check.
Point is, cars don't cure themselves. When an issue starts, it tends to get worse if not repaired.
