Fuel Leaking from T -- What Part is this
1986 - Convertible
Crack in the rubber T ... fuel leaking --- is there suposed to be fuel in this line?
What part is that that it's connected to?
There should not be fuel in the line...vacuum line to the diverter valve which allows air from the air pump into the exhaust manifold to help fire the cat on start up/warm up.
Thanks John
It just recently started to start with several cranks where before it would fire right up ... like it was flooded maybe. Do you think I have a leaking fuel injector?
Your fuel pressure regulator diaphragm is ruptured. FIX IT NOW!!!!!!!!!!!!!!!!
Your engine might look like this if you don't (fortunately I had a fire extinguisher in the car -- that's where all the white powder came from):
Actually Cliff just powdercoated his engine white.
Take that vac line OFF the regulator and start the engine. GAS WILL spray out of the reg vac fitting. There is no doubt in my mind.
Plan on buying a new regulator diaphragm for about $75 or a whole new reg for around $125 (adjustable)
Hopefully you did not do any damage to the pistons or rods by "hydro'ing" the engine trying to force it to start when a cyl was full of gas. See the other thread about the broken piston skirt.
FPR Bone dry
Going to do a fuel pressure leak down test tonight.
Just checked the fuel pressure
Idleing the pressure is rock solid at 40PSI. Shut the engine down and the pressure jumped to 45PSI. Within 5 minutes the pressure dropped to 12PSI and so far it's not dropping anymore. I guess that's a fail.
Do I still have to worry about hydrolock?
PS: After more than an hour it dropped to 0PSI
That plastic vacuum line connects directly to the FPR. I don't see how the FPR could NOT have fuel in it. The vacuum in the plenum will suck the fuel into the plenum and then it runs down into the cylinders. When I took my plenum off after the fire fuel poured out of it.
The right angle connector here on the far left goes to the FPR. The one next to it goes to the plenum vacuum source:
3D-Aircrew (03-11-2018)
Must be draining from the plenum
Like I said before the vacuum connection on the FPR was dry as a bone.
You might have a very slight leak, but your FPR diaphragm HAS to be bad. I wouldn't take a chance. Fires are NOT fun (had two of them).
Disconnect the AIT sensor underneath the plenum, a couple of vacuum hoses on the rear passenger side of the plenum and one vacuum hose directly underneath the throttle body.
The plenum should just lift out without damaging the runner gaskets. (The Throttle Body should be removed first, if the throttle body coolant hoses haven't been bypassed).
The FPR is now accessible and can be replaced.
Weekend project
I'll be driving the wife's car while she's out of town and parking the 'vette till the weekend.
