Head / Cam TPI Combo
Old 07-16-2014, 10:04 PM
jim88-Z52
jim88-Z52's Avatar
Default Head / Cam TPI Combo
I have a '90 l98 6spd car i want to upgrade cam/heads on. I have settled on the AFR 180's after considering Trickflow 175's (to keep compression up). The 90 cars are supposed to have 10.25:1 so the 65cc heads will take me down some, to about 9.5. I plan on running a .028 gasket to get some back, and i'm looking at a cam i think will be a good compliment to the car and heads, specs below. The car already has upgraded TPI hardware, AS&M runners, Accell base, ported plenum. The exhaust is Hooker SuperComp 1 3/4 long tubes and Corsa catback. Also have 1.6rr already in place and the car runs well. The cam is the Lunati Voodoo 262, i don't see many people here running it but it would seem to be a good fit, seems very much like the lingenfelter 211. This cam by my calculations would give me right about 8.00:1 DCR which would be good, and fit the modified TPI well. This would seem to be a good fit to me, am i missing something? Any input appreciated before i start spending $$$ :-).
Hydraulic Roller Cam. Great choice for stock to mildly modified engines, works well with OEM style injection, great inboard /outboard marine cam for economy and skiing. Good mileage and torque increase.
Advertised Duration (Int/Exh): 262/270
Duration @ .050 (Int/Exh): 211/219
Gross Valve Lift (Int/Exh): .507/.515
LSA/ICL: 112/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1600-5600
Includes: Cam Only
Old 07-16-2014, 11:13 PM
C4in mesa
C4in mesa's Avatar
I would contact PCM For Less NC and run this combo by them.
Old 07-16-2014, 11:56 PM
fl_799
fl_799's Avatar
Jim,
I love your setup.
Any thought towards having your 113 heads ported to bypass the compression 'issue, keep the 58CC chambers? My brother has a similar setup (Big mouth, AS&M runners, 1.6's, TPIS Headers etc) on his '90 and we are discussing similar head/cam options. I like the idea of sending his heads off to Lingenfelter for their CNC job or another reputable porter and be done with it.
Old 07-17-2014, 12:10 AM
jim88-Z52
jim88-Z52's Avatar
i though about that and inquired with TPIS. They want $1250 to port and redo the heads. I believe Lingenfelter is a little higher. That's just a little less than brand new modern heads. i don't want to put that kind of $$$ into 113 heads. I only want to do this once, if i do it again it's because i'm doing a 383, and the AFR's will translate over better then the 113's. That's why i was originally looking at the Trickflow 175's. They amount to ported out 113's but are more modern, and brand new.
Old 07-17-2014, 12:23 AM
Curveit
Curveit's Avatar
AFR will cut the Heads to 58 CC for a bit extra.
Old 07-17-2014, 12:34 AM
jim88-Z52
jim88-Z52's Avatar
I think they have to angle mill to get down that far, and starts to affect the flow. With the cam i was looking at dynamic compression would be at 8.00:1, which i think isn't too bad.
Old 07-17-2014, 02:00 AM
DanielRicany
DanielRicany's Avatar
Check out Fel-Pro 1094 head gaskets. 0.015" compressed thickness, and with stock deck height usually at 0.024", that puts you at 0.039" quench area which is perfect for running a good amount of timing. And it'll boost your compression up some.
Old 07-17-2014, 02:06 AM
mcm95403
Support Corvetteforum!
mcm95403's Avatar
If I hadn't been so concerned about passing CA smog I'd have run that Lunati cam - it looks great!
Old 07-17-2014, 09:50 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
That Lunati oughta pass smog no problem
Jim good combo you got planned there dont change a thing;sounds good
bout the only other thing you can do is take the grinder to the base. Not huge gains but they are there...or do it later if you want a little more
Spend $ on the tune it will pay off.
To Head / Cam TPI Combo
Quick Reply: Head / Cam TPI Combo
