95 with Service Ride Control light?
Old 07-05-2014, 08:13 PM
95wht6spd
95wht6spd's Avatar
Default 95 with Service Ride Control light?
FX3 system. I checked for codes,only had an old H27 code. I cleared that one. Started car and Ride Control light still on. Checked codes again, and nothing, just C12.
Ay ideas?
Old 07-06-2014, 12:40 PM
Red Dwarf
Red Dwarf's Avatar
Sounds like your using pin #4 instead of pin#3.
Can't remember exactly, other than SRC has it's own pin number???
Old 07-06-2014, 02:31 PM
FASTAZU
FASTAZU's Avatar
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
This post my be of some help to ya.
http://forums.corvetteforum.com/c4-z...rol-light.html
Old 07-06-2014, 05:55 PM
95wht6spd
95wht6spd's Avatar
Yes, I read that first before porting, didn't really help, unless my controller is out, but I think that is unlikely but coud be. I guess that woud not set code?
Old 07-06-2014, 05:57 PM
95wht6spd
95wht6spd's Avatar
Yes, 4 and 12. I thought 3 or 4, and it didn't matter?
Old 07-06-2014, 06:29 PM
95wht6spd
95wht6spd's Avatar
Ok, you are correct, found another post that says ground 3 to 4 or 5, but I tried, and only thing that gives me codes is 4/12.
http://forums.corvetteforum.com/c4-g...-light-on.html
Post 8
Old 07-06-2014, 06:35 PM
Red Dwarf
Red Dwarf's Avatar
If you turn the ignition on 3 times without driving it will set a code. You probably already tried that.
Do you have the FSM?
Old 07-06-2014, 07:26 PM
95wht6spd
95wht6spd's Avatar
Yes, I have a FSM. Wondering why I am not getting into diagnostic mode when I do the 3/4 or 3/5? Only when I do the 4/12.
I have not driven it since checking yesterday and today, so I do get the C12 code, but that is when I do the 4/12.
Old 07-06-2014, 09:17 PM
95wht6spd
95wht6spd's Avatar
Took of front actuators, they are good, but right shock rod spins freely when I turn it, and never stops. I think all shocks are good, as far as dampening, but this one just won't adjust.
The rod spinning, does not affect the shock, other than changing the settings correct?
Now I have to figure out what I want to do. Already had the shocks rebuilt once, rods replaced, and revalved to marraca setting. I think I am going to go to a softer standard shock.
Old 07-07-2014, 09:43 AM
Red Dwarf
Red Dwarf's Avatar
You'll get it worked out, good luck.
To 95 with Service Ride Control light?
Quick Reply: 95 with Service Ride Control light?
