96 Headlight Repair...I'm Baffled!
Okay, just repaired my headlight on the driver side of my 96 with new gear/bushings because I was hearing the motor run for about 5 seconds when they were turned on/off.
When I had the headlight motor apart the original gear/bushings seemed to be fine, but since I took the time to take it apart figured I might as well put in the new gear/bushings.
Put it all back together, hook everything up...and flip the headlight switch and.......the headlight motor still runs for 5 seconds!
What did I miss? Is there some sensor in the headlight motor that tells it when to shut off?
I'm baffled at this point...
The headlight motor controller senses that the headlight has reached the stops and turns off the motor. Sounds like your problem is inside the controller. I suggest taking it apart to see if you can spot anything obvious.
My L/H side headlight does the same thing - except it blows the 10A "Gauges" fuse when it keeps trying to turn over (why the Gauges fuse I'll never know).
Cliff, where/what is this "controller" you speak of?
Hhhhmmmm, will have to look into that further. The problem is only with the LH side, the RH side operates as expected.
Cruise-In II Veteran
I thought those were (3) relays
Bac22 - read your post on my thread. I'll be following yours too.
Side Issue - I thought I'd do a little exploratory surgery and took the motor (the motor not the gear) apart. Inside I see there are two electrical leads that are held agaist the shaft of the motor with 2 springs. (almost kinda like brushes in a drill ??) Anyway, I found nothing of consequence. Carefully put everything back together. I had to fashion a couple strings to loop around the wires to hold back the leads against the spring while I lower the motor shaft back into the housing, then slip the string loops out releasing the springs. BUT now that motor won't turn over!!!
Any ideas I missed? The electrical leads ARE carrying voltage when switch is thrown.
Had a bleeping mouse living in that area a few years back and it caused some problems which I suspect is what game headaches with the PKE, now it looks like the bastard caused the issues with the CCM since both are in the same location!
Oh well, other than the headlight, no codes and the car is running fine...probably live with it for this year...next years project!
Of course moral of the story is that don't always assume gears/bushings! If I had done this simple test from the start I would have realized it wasn't a gear/bushing problem.
