Very rough idle
Old 05-30-2014, 08:20 AM
BishShip3
Cruising
BishShip3's Avatar
Default Very rough idle
Bought my 87 late last year and it always had a rough idle. Did a complete tune up including new distributor. Just finished putting new intake manifold gaskets in. New EGR valve and oil pressure sensor. Ran and idled great. Parked it for a few minutes and then when I started it back up, it was idling worse than ever. Runs great when driving. What to try next?
Old 05-30-2014, 09:37 AM
leesvet
leesvet's Avatar
are there ANY SES lites ???
codes?
if not, I can almost guarantee you that your injectors are toast. have them ohms tested then call Jon.
Old 05-30-2014, 10:20 AM
playsdixie
playsdixie's Avatar
you didn't mention the iac....have you checked it/replaced it?
1 check for codes first
2 make sure your NEW egr valve is working
3 check your Iac
4 check tps/ min idle adjustment
5 get a fsm...gm.....check fuel pressure
good luck....
Old 06-02-2014, 11:49 AM
BishShip3
Cruising
BishShip3's Avatar
Thanks guys. It looks like it's a vacuum line issue.
To Very rough idle
Quick Reply: Very rough idle
